Z2 750 crank (Bossie the Kaw) 20 Sep 2015 19:15 #691100
  • Tyler
  • Tyler's Avatar
  • Thank you received: 92
I'm curious so I started doing some maths... something still doesn't add up.
Stock K1000 is as follows
Bore: 70mm
Stoke: 66mm
Disp: 254cc
V(TDC): 33cc
CR = 8.7:1
Stock Bore with 10.25:1 Weiscos
Bore: 70mm
Stroke: 66mm
Disp:254cc
V(TDC):27.5cc
CR = 10.25:1
Now lets look at the 750 crank with the 2.5mm Deck height measured with stock pistons
Bore: 70mm
Stroke: 58mm
Disp: 223.2cc
V(TDC):42.6cc
CR = 6.2 : 1
Now again with 10.25:1 pistons
Bore: 70mm
Stroke: 58mm
Disp: 223.2cc
V(TDC):37.1cc
CR = 7.0 : 1
Did I miss something here?
"74 Yamaha DT 400 Enduro
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 02:59 #691121
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Nice analysis Tyler, I wanted to calculate it exactly but didn't have the combustion chamber volume V(tdc)
If you are right on the 33cc V(tdc) , and the Wiseco are definitely exactly 10.25 then the numbers look right to me.
I'm getting 1016cc on those bore and stroke numbers.
Just an extra base gasket 0.5mm makes a measurable difference, so 2.5mm on the stroke will be very noticeable.
Those forged pistons and low CR woud be a good turbo bike project I guess.
Running-in will leave the unworn top part of the cylinder rough and could be a problem if you change the crank later.
Not really sure.
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 03:15 #691128
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2609
That's what I said. It doesn't add up. If it weren't for the 2.5mm drop, I was ready to accept that I made a mistake and it was a 903 crank and admit it. After all it was 28 years ago.
www.kawasakiz1.com/Kawasaki-Z2.html
That's why I've been trying to identify the crank. It shouldn't be that difficult. I was on eBay yesterday looking at crank shafts. The markings were all letters, this one has the number 45 stamped on it. I don't know if that means anything. So the nagging question persists. It was suggested I mark a wire at BDC, then at TDC and measure the difference, this I will do.
By your chart it goes from 42.6cc to 37.1cc so wouldn't the overall displacement be effected too?
I'd like to put this issue to bed for good.
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 03:35 #691133
  • kawi810
  • kawi810's Avatar
  • Thank you received: 11
Tyler, if your math is correct and it seems to be .that would make it 892.8 CC engine with a compression ratio of 7;1 if anybody can verify the combustion chamber volume and piston dome volume . that would help.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 03:45 #691138
  • Tyrell Corp
I'm getting 6.24 and 7.02 respectively, assuming the other numbers are right. This is best done by direct measurement of cc 's of oil in the combustion chamber and then summing the piston crown hump displacement.
CR = swept volume + TDC volume divided by TDC volume.
Am I wrong on this ?
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 03:56 #691139
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
Take the power wire of the Dyna and stick a comp gauge on it...... if your getting 100-110-120 psi wouldn't that show it ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 04:03 #691141
  • SWest
  • 10 22 2014
That would be unreliable due to the new rings and only 200 miles on it. I'm checking my valve adjustments this morning. I will do the wire test. I have some heavy gauge wire I can use. I can measure at the side where the piston is flat and then measure the center of the dome if that would help.
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 04:51 #691149
  • Tyrell Corp
Not sure it would.
A cc syringe and plate glass with hole in it over combustion chamber sealed with grease and filled with oil and no bubbles gives the combustion chamber volume, usually 1 cc within factory spec unless it has been skimmed or had a valve job.
Then, unless a perfectly flat top piston with no valve pockets, you calculate the piston dome displacment which comes from direct oil cc measurement.
You might be able to get a rough measure by tipping the bike on an angle, filling a bore through the plug hole with oil at TDC, noting the volume, then go to BDC and see how much you add, using the bottom of the spark plug thread as your fill mark.
Add the first two then divide by the first. Probably accurate within less than half a point of compression ratio I guess.
Usually the piston dome is above the deck height and subtracted from the combustion chamber volume and gasket width to give V(tdc) , in this case it will be much less, that's why we are making assumptions by back calculating from factory specs and some sort of direct measurement might be neccesary.
Last edit: by Tyrell Corp.
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 05:55 #691158
  • SWest
  • 10 22 2014
If nothing else it would give me a stroke measurement. If it turns out to be 66mm, OK, it's a 903 crank. If anything else, it's a 750.
8mm would be a lot to miss. :unsure:
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 06:19 #691161
  • Tyrell Corp
I get it, you are measuring the stroke length with a wire.
The more I think about it, I think Tyler's numbers might be out , as V(tdc) is based on the 900 crank throw, shorter stroke = higher V(tdc) number.
Try the oil fill test , you got me interested now. Otherwise I get easily distracted on oil seal threads :woohoo:
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 06:40 #691166
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Hind sight is 20-20...LOL....
it sure would have been nice if you had measured with a steel rule how far the piston drops from TDC in 180° !! HA ha
I would not be surprised to find out you do not have a 750 crank from what everyone is saying.
I think you "might" be able to drop a straight wire in a plug hole and mark it off against a top fin and rotate the engine to see how far it goes up or down.... etc.
A negative 8mm would be fairly easy to see if you can keep the wire straight up and down ....and always compared to the same fin and the same spot the top of the piston.
Seems like a goofy backyard mechanic way to do it, but what the heck... lol
8mm, that's .315" or 5/16" of an inch from a 903 at 66mm / 2.6" stroke.
So if you measured only 2.3" I guess it is a 750 crank.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Z2 750 crank (Bossie the Kaw) 21 Sep 2015 06:46 #691169
  • Tyler
  • Tyler's Avatar
Tyrell Corp wrote: I'm getting 6.24 and 7.02 respectively, assuming the other numbers are right. This is best done by direct measurement of cc 's of oil in the combustion chamber and then summing the piston crown hump displacement.
Your correct.
CR= V(BDC) / V(TDC) where V(BDC) = V(TDC) + Cylinder displacement
If you take the stock displacement and CR you can calculate V(TDC) that includes chamber volume + Gasket+ deck height - piston dome
Then you can determine the additional piston dome volume for the 10.25 : 1 pistons
Again this is just estimation, the real measurements would be needed, but it should be in the ball park, and that doesn't look too good.
Someone familiar with these engines can comment about the normal head volume and so forth, I haven not had a 1015 apart.
In Swest's case its the reduction in cylinder displacement that really knocks the CR.
If this is the case with your engine Swest you may need to deck the block and plane the head if you want to run it that way.
The following user(s) said Thank You: Tyrell Corp
Last edit: by Tyler.
