Difference between KZ1000 and a MKII 12 Jun 2010 14:28 #375288
  • Lazyman06
  • Lazyman06's Avatar Topic Author
  • Thank you received: 3
Finally got the KZ home but can't tell if it's a MKII or not what are some of the tell-tell signs?
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Difference between KZ1000 and a MKII 12 Jun 2010 14:39 #375289
  • hydrolazer
  • hydrolazer's Avatar
im told by the square cam housing
\'79 kaw 1000 ltd
Difference between KZ1000 and a MKII 12 Jun 2010 14:44 #375290
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 301
The MKII is an upgraded 1015cc KZ1000 motor. So, post the VIN numbers from the frame and motor and the ID can be discerned from what series the numbers fall into. Mother Kawasaki was a bit tricky at times, with engine covers from transitional bikes that externally resemble the MKII motors but internally were still the older series 1015cc KZ1000 motors.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Difference between KZ1000 and a MKII 12 Jun 2010 14:44 #375291
  • otakar
  • otakar's Avatar
  • Thank you received: 29
A MKII has the clean air porting in the head. This is evident by the two hoses mounted to the top of the valve cover at the exhaust side of the engine. The bike would be a 1979 or 80
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: by otakar.
Difference between KZ1000 and a MKII 12 Jun 2010 15:10 #375306
  • Lazyman06
you mean on the right side right because unless i'm mistaken it came stock with duals
Difference between KZ1000 and a MKII 12 Jun 2010 15:36 #375312
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2067
Otakar is referring to the exhaust side of the head, which is toward the front, as opposed to the intake side of the head, which is toward the rear.
Difference between KZ1000 and a MKII 12 Jun 2010 16:42 #375323
  • larrycavan
  • larrycavan's Avatar
  • Visitor
True but there were smog heads on small pin crank motors that were not MKII. Early 79LTD got the old motors but had smog head.
An easy way to spot MKII cases is they have an extra strengthing rib on the clutch side. KZ's didn't have that.
Look at the back side of the clutch area. If there are two verticle strenthening ribs, the cases are MKII. If there is only one, it's KZ cases. You can tell what's inside if you pull the valve cover and count the teeth on the cam sprockets. 30T = KZ, small in crank. 32T = MKII with big pin crank.
MKII motors were a change to a unified type of engine case that could be used for shaft & chain drive bikes. They also beefed up a few other tid bits.
Last edit: by larrycavan.
Difference between KZ1000 and a MKII 12 Jun 2010 16:53 #375325
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Thank you received: 181
plus.... the 79/80 smog heads are ONLY on the US version of the bike, all other countries received the engines WITHOUT the smog ports
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Difference between KZ1000 and a MKII 12 Jun 2010 19:18 #375343
  • larrycavan
  • Visitor
MKII Motor
See the extra strengthing rib by the clutch?
Also notice the shape of the transmission cover near the bottom in the rear. They're also different than KZ.
Difference between KZ1000 and a MKII 12 Jun 2010 19:46 #375351
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
larrycavan wrote:
MKII Motor
and polished engine covers! oh wait thats one of larrys motors! :laugh:
Difference between KZ1000 and a MKII 12 Jun 2010 22:27 #375381
  • porchev914
  • porchev914's Avatar
  • Thank you received: 19
Is there any way to reference by the number of ribs on the front of the case? I had also heard the main reinforcing web between the oil filter housing and the main bearing mounts is thicker (.6"). I ask because based on the front ribs and the thicker web under tha pan, I would have MKII cases, but it's not a mkII engine. Thoughts?
FRANKEN Z!
Difference between KZ1000 and a MKII 12 Jun 2010 23:00 #375385
  • supercharged
  • supercharged's Avatar
  • Thank you received: 7
what are the teeth count differences on the crank? 15 and 16??
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
