- Thank you received: 2216
Project KZ440 Scrambler
22 May 2024 18:30 #899538
by TexasKZ
Replied by TexasKZ on topic Project KZ440 Scrambler
Be sure not to knock loose the little rubber pads on each weight.
- Adrian719
- Thank you received: 3
22 May 2024 19:23 - 22 May 2024 19:33 #899544
by Adrian719
Replied by Adrian719 on topic Project KZ440 Scrambler
Well just realized those two little broken pieces are actually from the weights. So I guess I'll have to replace this assembly..
This is definitely becoming an annoying project with all the little things.
Stuff on order:
Carb holders
Fuel tap rebuild kit
Stuff on order:
Carb holders
Last edit: 22 May 2024 19:33 by Adrian719.
- Adrian719
26 May 2024 18:05 #899784
by Adrian719
The new timing unit is in. I need to figure out how to correct the timing because now it won't start.
I also ended up picking up a KLR650 today, so the new plan is to finish this project and sell it.
