80 KZ 1000 LTD rebirth
- Rryanflakz
26 Feb 2024 15:47
The following user(s) said Thank You: sf4t7, Wookie58, Kelly E
- Kelly E
Re: 80 KZ 1000 LTD rebirth
26 Feb 2024 15:59
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- Rryanflakz
- Cra-z1
26 Feb 2024 17:36 - 26 Feb 2024 17:41
Looks good. Are you using the larger Z1 tank. It doesn't look like the LTD tank. Im Just starting a similar project with the 80 KZ1000 ltd frame however I will be putting in a spare KZ900 engine I have. In going to use the bigger tank but will need to remove the steering lock that is on the side of the neck and rework it to accept the older lock on the bottom on the triple tree. I see you have the Delkivic. Mine should look similar but im thinking of using the 78 black paint scheme with the gold stripes with a black engine. I was kinda thinking of using a red withe the 78 gold strips and looking at yours I just might do that.
Show us a few more photos
Last edit: 26 Feb 2024 17:41 by Cra-z1.
- Rryanflakz
26 Feb 2024 17:55
Yes z tank. The stock tank is jacked inside….bike wont period correct but I wasnt going for that…the Delkevic I am impressed for ma 400 header….I am going to run open baffle to get that classic KZ sound
- Rryanflakz
- Rryanflakz
26 Feb 2024 18:05Looks good. Are you using the larger Z1 tank. It doesn't look like the LTD tank. Im Just starting a similar project with the 80 KZ1000 ltd frame however I will be putting in a spare KZ900 engine I have. In going to use the bigger tank but will need to remove the steering lock that is on the side of the neck and rework it to accept the older lock on the bottom on the triple tree. I see you have the Delkivic. Mine should look similar but im thinking of using the 78 black paint scheme with the gold stripes with a black engine. I was kinda thinking of using a red withe the 78 gold strips and looking at yours I just might do that.
I bought the painted kit from Z1Parts…guys are great to deal with…..stock tank is hosed, earn up inside so i figured f it just put the bigger Z tank on…I actually like the bigger tanks
- Cra-z1
26 Feb 2024 19:19
So did you find that the steering lock on the side of the steering tube interferes with the tank. I cant tell if you removed it from the photo. I have the same Delkivic on my Susuki GS1100. On the KZ I think I will go with the straight muffler. Otherwise it looks like the exact look im going after. I will be using the stock air box also
- Rryanflakz
27 Feb 2024 10:16
My brother lost the original key so the steering lock is still installed and the larger tank fits fine with the steering lock installed. I will probably pull the front end apart and remove the lock all together. This bike wont leave my sight and will never be left out overnight.
- Cra-z1
27 Feb 2024 13:00
My tank hits the lock and I don't have a key either so I will just cut it off grind the weld down and weld up any hole left over. I may not deal with a lock either but my triple tree is from a 79 kz
- Rryanflakz
27 Feb 2024 13:12
Hmmmm. Thats weird tank is hitting …no issue with mine
- Rryanflakz
