77' KZ1000 LTD 05 Aug 2022 07:29 #871716
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
  • Thank you received: 52
Because of my 16 rearwheel and higher revs i run 15/32 with 630chain. Bike is a Z1B 1015cc and VM 29 smoothbore pumpers
77' KZ1000 LTD 06 Aug 2022 20:30 #871793
  • Kelly E
  • Kelly E's Avatar Topic Author
  • Never Give Up. Never Surrender
  • Thank you received: 304
Today my buddy Paul started disassembly of the carbs. I pulled the rear wheel and brake system for disassembly and cleaning. I had to fill and use the parts washer because the bike is so dirty and greasy. The new seat came and I'll have to use the stock seat lock catch from the other seat.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Last edit: by Kelly E.
77' KZ1000 LTD 11 Aug 2022 15:15 #872078
  • Kelly E
Today I pulled the swingarm out and found dual needle bearings on each side. I read in the Clymer manual that only ZR-1's got the dual needle bearings. Did the LTD's get them too?
1983 Honda CB 1100F
And more
77' KZ1000 LTD 11 Aug 2022 15:40 #872081
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2051
Parts diagram at Partzilla says yes.
www.partzilla.com/catalog/kawasaki/motor...bsorbers-77-78-b1-b2
77' KZ1000 LTD 18 Aug 2022 13:49 #872440
  • Kelly E
I've been busy pulling and cleaning up parts. I think I'm going to replace the Kerker with a Delkevik stainless exhaust. The Kerker is still solid and useable but it's got some war wounds, missing chrome, dents and dings. We put a Delkevik on our 80' Suzuki GS 1100E that we just finished. It is lighter and sounds great. I wish the Kerker looked better because I really wanted to use it.
1983 Honda CB 1100F
And more
77' KZ1000 LTD 24 Aug 2022 16:25 #872784
  • Kelly E
I've been busy with cleaning 45 years of crap off the motor. Today we discovered that both front axle nuts are seized. My pneumatic impact gun didn't budge them. They are currently trying to soak up some Kroil. The next step will be heating up the nut. From the look of the tab washers on the brake rotor bolts it's likely the original wheel bearings so I need to get the axle out.
1983 Honda CB 1100F
And more
77' KZ1000 LTD 24 Aug 2022 16:44 #872786
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1895
Did you try to loosen the fork leg axle clamps first?
77' KZ1000 LTD 24 Aug 2022 17:19 #872789
  • Kelly E
Yep, we had the axle clamps loose. It has been way overtightened . I'm soaking in Kroil overnight. Tomorrow I'll try again, if it's still seized I'll try some heat. Sooner or later I'll get it apart.
1983 Honda CB 1100F
And more
77' KZ1000 LTD 08 Sep 2022 10:38 #873561
  • Kelly E
I decided to pull the motor to sandblast and paint the frame. Too much rust and scratches to look past. I finally got the front axle apart, the axle had rusty threads on both sides. I also had to make a tool from an old tool to take apart the forks. I'm learning that my uncle was a little bit lax on doing maintenance.
1983 Honda CB 1100F
And more
77' KZ1000 LTD 13 Sep 2022 15:26 #873844
  • Kelly E
Well after 3 rounds of cleaning the motor is starting to look like it is made from aluminum and not 45yo baked on grease and oil. I figure it will take another 3 or 4 rounds of cleaning to get it looking even close to good enough.Still waiting for the blast media to blast the frame. Everything else fits in the blast cabinet including the swingarm.
1983 Honda CB 1100F
And more
77' KZ1000 LTD 13 Sep 2022 15:50 #873845
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 292
Looking good! keep up the good work.
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
77' KZ1000 LTD 15 Sep 2022 19:47 #873954
  • Kelly E
Today I started blasting the frame. I made it about 3/4ths of the way through it before I had to quit for the day. In the morning I'll go get another bag of blast media so I don't run out. If the weather cooperates it will be done tomorrow.
1983 Honda CB 1100F
And more
