1973 Z1 rebuild 31 Jul 2022 03:51 #871368
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
You did a great job on the black paint in the DOHC sections.  How did you paint them?
1973 Z1 rebuild 31 Jul 2022 04:12 #871369
  • blackozvet
  • blackozvet's Avatar Topic Author
  • Thank you received: 79
well I have to admit I didnt paint them, they are actually the original dynamo and ignition covers !
I took them off years ago and put chromed aftermarket covers on the engine, and by some incredible fluke I actually wrapped the original covers up and packed them into a box with other bits and pieces.  More good luck than good management really !
The covers had some scratches from the bike being dropped, so I started with 80 grit paper to get the scratches out and worked up to 1200, being careful not to hit the black DOHC's .
1973 Z1 900 Kawasaki
1973 Z1 rebuild 31 Jul 2022 05:05 #871372
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
The bike looks great!  Thanks for taking the time to share your project and post up lots of photos!
For what it's worth, when it comes to polishing engine cases, I've found that using a DA sander with 220 grit sandpaper does pretty good to remove deep corrosion pitting.  For the nooks and crannies, a dremel with stainless steel brushes works well.  Next, a coarse sisal wheel with black cutting compound is used on a buffing motor.  I use a car polisher motor.  Use heavy gloves because the case will get HOT.  The combo of sisal w/black compound will shine up the case very nicely, but the finish will be very close to OEM, not mirror bright.  For that, you need to move to a fluffy wheel with fine grit polish of some sort.  I came up with this method because I'm lazy.  Polishing by hand is way too much work for me.  The method highlighted will allow you to clean up a full set of cases in just a few hours of work.
Last edit: by Nessism.
1973 Z1 rebuild 31 Jul 2022 07:50 #871382
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1971
Both you guys do awesome work !!!!!
I like easy  and fast  too. No patience anymore
1973 Z1 rebuild 01 Aug 2022 04:55 #871440
  • blackozvet
this is how I feel while polishing alloy
1973 Z1 rebuild 01 Aug 2022 05:31 #871443
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 597
blackozvet post=871366if they had alloy polishing at the current Commonwealth Games I think I would be in contention for a gold medal !
The engine covers are done - now I can take them all back off and get on with putting things together.
Those covers look great!  Good job of matching the OEM finish.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
1973 Z1 rebuild 01 Aug 2022 10:59 #871459
  • hardrockminer
No wonder they look like originals!!
Back in the day I had a Z1B that I eventually sold when I started a family.  But for some reason I kept the tools.  Fast forward 40 years and I bought another Z1B, without a tool set.  Now it has one!
1973 Z1 rebuild 06 Aug 2022 01:24 #871753
  • blackozvet
The wheels are back,  having been re-spoked with stainless spokes, and fittingly the old battlax gets some Bridgestone Battlax tyres (BT46)
1973 Z1 rebuild 08 Aug 2022 05:41 #871876
  • blackozvet
1973 Z1 rebuild 08 Aug 2022 07:51 #871877
  • BCScott
  • BCScott's Avatar
  • Thank you received: 97
That bike's going to look terrific.
Back in the saddle and loving it! KZ1000A1
The following user(s) said Thank You: blackozvet
1973 Z1 rebuild 09 Aug 2022 04:16 #871915
  • blackozvet
Found a new key ring tag !
1973 Z1 rebuild 09 Aug 2022 05:21 #871916
  • hardrockminer
Is that rear rim a Takasago?  The key flag may have come from a KLR.  I had one with mine.
