- Thank you received: 2280
And finally, Wookie's 82 begins !
On the top of the motor behind the cylinders (it replaces the stock oil switch housing)Is this manifoil fitted on the back side of cylinders where the oilmanifoil is fitted or on the cooler?
- Rolf1976_KZ900
- Thank you received: 159
Over the top and between the carbs is the plan (1-2 & 3-4)Okay thanks so then you will run 2 braided an fitting hoses on the side of cylinders
This turned out to be PITA with multiple different angles to take into account when notching the pipe (hence why I have only done one side so far !) still on the upside, looking at the rest of the frame with the paint removed my crappy welding could pass at factory It's holiday in the UK tomorrow so hopefully will get the other side wrapped up. I think it looks way better and should also be significantly stronger
- Thank you received: 2053
Yes,right there.Here are some pics about the location and my oil cooler line routing.Is this manifoil fitted on the back side of cylinders where the oilmanifoil is fitted or on the cooler?
- willemZ900
- Z1B 4 ever
- Thank you received: 56
- calum
- Thank you received: 401
This sounds strangely familiar......but having waited so long I refuse to compromise on how I want it to be. I am a "glutton for punishment" and ...
Current Project:
www.kzrider.com/forum/11-projects/616901...-spare-parts-project
1977 KZ1000 Restomod ( www.kzrider.com/forum/11-projects/614517-1977-kz1000-restomod )
2000 BMW F650GS
PS: coils need shorter bolts
- Thank you received: 2216
