And finally, Wookie's 82 begins ! 25 Sep 2022 01:37 #874476
  • calum
  • calum's Avatar
  • Thank you received: 390
Did you make any progress on your days off, or did the daily driver eat up all your free time?
And finally, Wookie's 82 begins ! 25 Sep 2022 02:44 #874481
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
  • Thank you received: 1783
Am working on the side panels currently, will update later
And finally, Wookie's 82 begins ! 25 Sep 2022 03:54 #874484
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
  • Thank you received: 250
It will get rear interesting real quick when they are done and the seat has a skin on it.
And finally, Wookie's 82 begins ! 25 Sep 2022 09:07 #874499
  • Wookie58
  • Away
  • Moderator
And so to the fruit of today's labours   I have finished re-shaping the left side panel so it now fits properly in it's new home and is pulled in a little tighter to narrow the old girl around the waist ( every little helps when you have short legs) I basically cut into three main parts and then added or removed material where necc so it still looks like a KZ panel just a little different (15mm longer at the front, 35mm longer at the back and 25mm shallower in the depth) I have included a before and after comparison with the right side. If you don't have one of these "hot rivet" guns you should get one, even before it was glued it was solid with just the rivets (with plastics getting harder to come by most would be repairable using this method)
I have then painted over all the joints from the back with "gloop" ( scraps of ABS plastic disolved in acetone to make a paste) the acetone eats into the surface of the plastic to make a permanent bond ( it's like adding another layer of plastic) just needs a light skim of bondo and some mounts now
The following user(s) said Thank You: calum, howardhb
Last edit: by Wookie58.
And finally, Wookie's 82 begins ! 25 Sep 2022 10:40 #874508
  • kzstreetfighter71
The definition of a Frankenstein bike.
And finally, Wookie's 82 begins ! 25 Sep 2022 11:16 #874513
  • Wookie58
  • Away
  • Moderator
Is that a good thing
The following user(s) said Thank You: kzstreetfighter71
And finally, Wookie's 82 begins ! 25 Sep 2022 12:23 #874515
  • kzstreetfighter71
Hell ya it is, creating something new from the old is the way to go.
The following user(s) said Thank You: Street Fighter LTD, calum, Wookie58
And finally, Wookie's 82 begins ! 25 Sep 2022 12:51 #874517
  • calum
  • calum's Avatar
Nice work, that's something I don't think I'll ever have a go at - too much patience required!
The following user(s) said Thank You: kzstreetfighter71, Wookie58
And finally, Wookie's 82 begins ! 25 Sep 2022 14:41 #874523
  • Wookie58
  • Away
  • Moderator
I did say I wanted to use as many OE parts as possible, I never promised to leave them stock though
And finally, Wookie's 82 begins ! 25 Sep 2022 21:48 #874541
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Extremely nice work. We need pics of them of the bike!
And finally, Wookie's 82 begins ! 26 Sep 2022 10:15 #874591
  • Wookie58
  • Away
  • Moderator
Thanks Doc, attached as requested. It's certainly on a journey and there isn't much "Ltd" left now
And finally, Wookie's 82 begins ! 26 Sep 2022 10:37 #874596
  • kzstreetfighter71
They nearly have a Z1 look to them, nice one.
Last edit: by kzstreetfighter71.
