1979 KZ650B Streamlined Restomod 19 Apr 2022 09:00 #865753
  • Oysteinaar
  • Oysteinaar's Avatar Topic Author
  • Thank you received: 12
Thanks for the tip!
​​​​​I'll sand down the edge and apply some clearcoat that I saved from the painting process.
I removed the handlebar today and checked the steering stem bearings, they were dangerously worn... I couldn't feel it with the handlebar mounted, but when only turning the triple tree it was very obvious.
managed to remove the bearings and glassblasted + painted the triple tree. Will mount it with fresh "all balls - tapered bearings" next time I'm home.
Kawasaki KZ650 1979
Last edit: by Oysteinaar.
1979 KZ650B Streamlined Restomod 11 May 2022 13:25 #866934
  • Oysteinaar
Passed the Practical driving test today
The tankset and everything else will be mounted sometime in the beginning of June.
All that remains after that is picking up the registration plates, fine tuning the carbs/ ignitionsystem, doing a brake "overhaul" and assemble/mount the fronk forks.
Kawasaki KZ650 1979
1979 KZ650B Streamlined Restomod 11 May 2022 16:06 #866944
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1720
Coming along nicely
1979 KZ650B Streamlined Restomod 05 Jun 2022 12:38 #868290
  • Oysteinaar
Wookie58: thank you!
It's now the beginning of june and I expect to finish the bike this this week!
Still have to modify the new front fender I got, and eventually get a new exhaust, but apart from that she will soon be on the road
Rebuilt the front forks, assembled the electric stuff, and some more... Registration plates are on the way in the mail!
Kawasaki KZ650 1979
1979 KZ650B Streamlined Restomod 08 Jun 2022 09:19 #868501
  • Oysteinaar
 ***A picture is worth a thousand words***
Kawasaki KZ650 1979
1979 KZ650B Streamlined Restomod 08 Jun 2022 10:01 #868503
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Looks stunning
1979 KZ650B Streamlined Restomod 08 Jun 2022 10:12 #868505
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Looks awesome.
For the gas tank lip - just leave it bare steel where it contacts the rubber seal like the OEM. no need to seal with resin - and unless its a gas resistant resin (most arent) it wont do anything anyway. Problems arise when the paint goes into the tank area that is sealed under the rubber lip and capillary action wicks it under the paint.
1979 KZ650B Streamlined Restomod 08 Jun 2022 15:36 #868518
  • Oysteinaar
Thank you for the kind words, and also for a helpfull comment!
I masked off about half a centimeter below the edge of the gas tank "lip" before painting, so it should be good to go, will double check tomorrow, and sand off a little paint if I have to!
Gave the exhaust a little (but very much needed) TLC today and mounted it. Fingers crossed for no leaks, will try to fire her up tomorrow
Kawasaki KZ650 1979
1979 KZ650B Streamlined Restomod 10 Jun 2022 09:06 #868608
  • Oysteinaar
Charged up the battery, and after giving her a little fuel & choke, she started right up! runs pretty darn good and clean too! I think I hit spot on with the carb-jetting, air filter & exhaust combination
Still waiting for the registration plates, all thats left to do now is to change the brake fluid and take her for a spin
Kawasaki KZ650 1979
1979 KZ650B Streamlined Restomod 11 Jun 2022 17:27 #868649
  • rstnick
  • rstnick's Avatar
  • Thank you received: 372
Looks great, well done!
You put your exhaust on the wrong side though.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
1979 KZ650B Streamlined Restomod 11 Jun 2022 18:46 #868654
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 361
sorry but the exhaust is right  correct as u sit on the bike
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
1979 KZ650B Streamlined Restomod 12 Jun 2022 05:36 #868663
  • Oysteinaar
Thank you
The exhaust was mounted this way when I bought the bike. I managed to get it close to 100% sealed after pulling it to pieces, sanding and polishing it up, so it wont be removed untill it has to
I dont see how it would be possible to mount it on the R-side, would have to invert the headpipes from left to right and turn the muffler upside-down, and then the brackets wouldn't fit right
Might be the wrong side, might be the right side, I dont know, never figured the make of the exhaust either. But it sounds and feels great
Kawasaki KZ650 1979
