1973 Z1 Maui 07 Nov 2021 14:39 #857609
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
I’ve contacted Ralph at paintwerkz. We’ll see how it goes.
I also found two instrument harnesses on eBay, maybe the last two in captivity. Weird that Doremi doesn’t make them.
ouch
PMC Japan makes a lot of Kawasaki stuff as well.... Both PMC and Doremi sell stuff through webike japan....
1973 Z1 Maui 07 Nov 2021 14:43 #857611
  • 750 R1
  • 750 R1's Avatar
1973 Z1 Maui 07 Nov 2021 17:52 #857620
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1892
Last edit: by Scirocco.
1973 Z1 Maui 07 Nov 2021 18:34 #857622
  • 750 R1
  • 750 R1's Avatar
What does the gauge harness look like ?, Doremi, PMC and M-tec chukyo have every other harness for the 900, I'm certain they would not have left any out, That picture you posted Scirocco is a PMC part....
japan.webike.net/products/22626961.html
1973 Z1 Maui 07 Nov 2021 19:15 #857624
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1008
The gauges each have two lights.  There is a two wire harness for each gauge.  They plug into the dash harness.  Z1A and B also have a brake light in the tach.
I think I have a set of them somewhere.  I looked in my harness box but they were not there...I will look in my electrical box tomorrow.
1973 Z1 Maui 08 Nov 2021 07:14 #857647
  • MauiZ1
  • MauiZ1's Avatar Topic Author
  • Thank you received: 19
Hopefully my order will come.
By the way, can anyone post a photo of how all this wire exits the back (front) of the gauges to head down to the headlight? My bike was in pretty bad shape and I don't think it was right.
1973 Z1 Maui 08 Nov 2021 09:30 #857652
  • hardrockminer
If you look at the back part of the dash panel you will see some indents that are designed to make room for the wiring to exit.  There should be two smaller indents and one larger one.
This morning I checked to find my gauge light harnesses.  Could not find them.  Maybe they are a figment of my imagination?
Last edit: by hardrockminer.
1973 Z1 Maui 08 Nov 2021 13:21 #857670
  • MauiZ1
Thank you HRM
Ive decided to fix the bashed up original tank. Oahu has a pretty big car culture and I made some calls and found a guy that does a lot of custom work. His Instagram is @808painter1. He’s done some pretty impressive stuff. I think the bike will be better if it has the original tank. My next problem would be paint. I can get paint from paintworkzus but getting it shipped here is tough. I have some research to do
1973 Z1 Maui 08 Nov 2021 15:33 #857684
  • Kaylinator
  • Kaylinator's Avatar
  • Thank you received: 74
Here is what John sent
This browser does not support PDFs. Please download the PDF to view it: Download PDF
I get an error when trying to open that. Are you perhaps able to drop it in the filebase?
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1973 Z1 Maui 08 Nov 2021 16:58 #857688
  • 4chrisbnvds
  • 4chrisbnvds's Avatar
  • Thank you received: 2
It looks like an interesting project. Good luck restoring/modifying it.
Thank you HRM
1973 Z1 Maui 08 Nov 2021 19:41 #857695
  • hardrockminer
I had the paint shipped to Canada from Arizona but I think it went by land carrier.  That's not as easy to do if you live in the middle of an ocean.  You might be able to pursuade Ralph to give you the recipe and let you go to your local painter to mix up a batch.
1973 Z1 Maui 08 Nov 2021 21:18 #857700
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 256
That tank is rough!  Best of luck restoring it.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
