  • Page:
  • 1
  • 2
absolutely beat bike 22 Jul 2021 17:26 #852300
  • kdoggin
  • kdoggin's Avatar Topic Author
  • Thank you received: 0
I've had this for a while, won't bore you with details, bike has many issues; bent steering stop, broken rear shock stud,messed up wiring, wrong steering stem head and gauge pods, gutless kerker...It will be a driver (hopefully) not a restoration, but any input will be appreciated
absolutely beat bike 22 Jul 2021 20:55 #852322
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
Worse ones have been brought back to life. Ask any questions you have, there are some amazingly knowledgeable and talented folks around here.
The following user(s) said Thank You: kdoggin
absolutely beat bike 23 Jul 2021 04:10 #852331
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1040
Are those wheels Lesters?
absolutely beat bike 24 Jul 2021 18:32 #852467
  • kdoggin
sorry, been thrashing, good thing i took off the rear wheel, brake shoes were un glued.  someone said they were
absolutely beat bike 24 Jul 2021 18:50 #852472
  • kdoggin
sorry, yes they are lesters
absolutely beat bike 25 Jul 2021 04:30 #852498
  • hardrockminer
It was a common mod back in the day and highly sought after nowadays.
absolutely beat bike 25 Jul 2021 08:59 #852511
  • ronnieV
  • ronnieV's Avatar
  • Thank you received: 293
And getting hard to find as well.
absolutely beat bike 28 Aug 2021 14:47 #854470
  • MauiZ1
  • MauiZ1's Avatar
  • Thank you received: 19
Is the project going?
absolutely beat bike 29 Aug 2021 03:43 #854497
  • kdoggin
thanks for the interest! and as a matter of fact it is running and driving. I've been on 4 rides (all successful). First one my license plate fell off because I was so exited. second one went 32 miles solo, third was about 50 miles with my highest top speed ever (about 60, don't laugh). fourth ride was friday after work, about 50 miles , half on dirt road, bike died , thought it blew up, switched to reserve. finally started, made it home about 25 miles on reserve, hehe. My buddy asked if I had enough gas before we left, I said " I should be good"
absolutely beat bike 29 Aug 2021 03:51 #854498
  • kdoggin
Sorry, meant to post project updates too. Finally got the right stem and head set so I could install correct dash and idiot lights, new tires, mac baffle for my $100 beat e-bay kerker, which sounds amazing. Motor is a 78 kz1000 b2 and carbs which have the 3rd carb vacuum port which I plugged after the first ride. carbs only have pilot air screws on bottom back of the float bowls, looks like the idle air screws are blocked off. The bike runs well enough to drive,but pops once in a while, sounds a little off, btw haven't synced carbs but bought the vacuum gauges to do it. today i will fab a center stand stop so it doesn't hit my chain and work on a horn.
absolutely beat bike 29 Aug 2021 05:16 #854503
  • ghostdive
  • ghostdive's Avatar
  • Thank you received: 118
I thought my 305 blew up the first time I took it for a long ride - yeah, I ran out of gas. Cue the most nerve-wracking 11 mile ride to the nearest station. First trips make me nervous
Glad your ride is up and running!
2001 ZX-6R
absolutely beat bike 29 Aug 2021 09:31 #854510
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1866
Good to hear another one is back on the road.
You have fuel adjust pilot screws. They might still have plastic caps on them. Emissions standards made Kawasakis cap them to limit end user adjustment so the bike would pass test. They can be removed, every set I have the caps are removed so I really don’t know how to but assume grip them with a set of needle nose and pull straight down.
Johnny’s vintage in Ohio sell a center stand bracket cheap if you’d like to look into it. www.johnnysvintagemotorcycle.com/product...enter-stand-stopper/
Popping is usually a symptom of air sneaking in, might need new carb holder boots.
Last edit: by Mikaw.
  • Page:
  • 1
  • 2
