  • Page:
  • 1
  • 2
74 Z1A 18 May 2023 22:09 #884890
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 261
Motorcycle porn!
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
74 Z1A 18 May 2023 23:33 #884891
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1831
Really nice work, be proud
74 Z1A 19 May 2023 00:42 #884893
  • Jonas_Z1000j
  • Jonas_Z1000j's Avatar
  • Thank you received: 31
It looks so good I immediately started browsing for Z1 projects
Z1000 J2 -82 not so running restoration object anymore
Z900RS -21 Green/Yellow
74 Z1A 19 May 2023 08:55 #884909
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 310
It is a Delkevic, polished stainless. great finish and center stand friendly. I will say when I initially installed it the bottom of the header was a lot closer to the ground than I liked. I fixed that problem by indexing the muffler about 10 degrees CCW and fabricating my own mount and center stand stop. There mounting hardware is worthless. By making the modifications I was able to get 1 1/2 to 2" more ground clearance.
I got my Delkevik exhaust system up closer to the frame too. I also made a new mounting bracket for the muffler but was able to use the centerstand stop. The original bracket had the hole it hangs from in the wrong place in my opinion. My bracket moved the muffler up as far as it could without interfering with the passenger foot pegs. I need to figure out a thinner rubber stop so the centerstand doesn't hang as low, I haven't drug it yet and I don't want to.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
  • Page:
  • 1
  • 2
