Project Sharkey, 1978 KZ650C2
  • rstnick
  • rstnick's Avatar Topic Author
14 Apr 2021 06:22 - 14 Apr 2021 08:05
#846668
I've had this KZ650 since 1984, buying it off a buddy I knew since Kindergarten.
She had 16,000 kms on her:
[img
I made changes right away, rear fender removed being one.
Over the years she has seen some different set ups;
[img
[img
2006 I found a Rickman Fairing.
[img
[img
Painted blue;
[img
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 14 Apr 2021 08:05 by rstnick.
  • rstnick
Re: Project Sharkey, 1978 KZ650C2
14 Apr 2021 06:31 - 14 Apr 2021 06:33
#846670
In the '80s she got repainted Candy Apple Blue.
[img
[img
Having the teeth on the lower fairing, she got the nicname Sharkey.
The last five years she has been sitting, since I bought a ZRX1100.
125,000 kms on her, so far.
[img
This past Winter, I started doing some maintenance to her, and getting new parts where needed.
A compression check gave readings of 150 psi across all four, so I'm not opening the engine.
Valve clearances will/have been checked and adjusted, as well as more...
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 06:33 by rstnick.
  • rstnick
14 Apr 2021 06:40
#846671
Part of the project this past Winter was installing a set of Keihin CVK32 carbs off a ZX600 Ninja.
I bought the carbs thinking they were ZR7 carbs, which was what's needed.
Thankfully the ZX600 carbs are the same size.
I followed Pablo's/z650Spirit's tutorial on installing the CVKs.
Also will use the stock ZRX shocks I have.
[IMG
[IMG
VM24SS carbs and air box removed.
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • rstnick
14 Apr 2021 06:44
#846672
I used a spare air box with a bit of damage around hole #2;
[IMG
[IMG
[IMG
Used some JB Weld to repair the damaged bit on the air box;
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • rstnick
14 Apr 2021 06:50 - 14 Apr 2021 06:51
#846673
While having the valve cover off to check the valve clearances, I also replaced some of the rubber bits while in there.
Had an extra cylinder head, so checked what shims were in it, and was able to use a few;
[img
[img
[img
ZRX1100 rear shocks on.
They are about two inches longer than the Konis currently on there.
I will bring the front end back up to stock level, as I've had the forks slid up in the triple trees for ages.
[img
[img
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 06:51 by rstnick.
  • rstnick
14 Apr 2021 06:56 - 14 Apr 2021 06:57
#846674
CVK carbs got Ultrasonically cleaned, and all new rubber o-rings and jets.
[img
[img
[img
The current Auto cam chain tensioner rigged up to be a manual locked set up, was replaced with an Ape cam chain tensioner;
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 06:57 by rstnick.
  • rstnick
14 Apr 2021 07:03 - 14 Apr 2021 07:04
#846677
The clutch, having over 100,000 kms on it, is getting some attention;
New friction plates.
New basket, as the old Cir Cycle clutch used an extra set of plates.
The plates being thinner, have grooved the basket fingers.
The clutch release mechanism got all new parts too.
[img
[img
[img
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 07:04 by rstnick.
  • rstnick
14 Apr 2021 07:07
#846678
CVK carbs installed.
New ZR7 carb manifolds and boots used;
[IMG
[IMG
A used clutch basket found.
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • rstnick
14 Apr 2021 07:12 - 14 Apr 2021 07:14
#846680
New battery and coils;
[img
[img
Coils and wires installed;
[img
Fork oil changed.
Last time I did it I had to slot the drain screw.
Bought new ones, five years ago.
Found them;
[img
[img
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 07:14 by rstnick.
  • ghostdive
  • ghostdive's Avatar
14 Apr 2021 07:17
#846681
I'm so excited to read this! This bike was always so cool to me, I didn't know it was sitting this whole time.
2001 ZX-6R
  • rstnick
14 Apr 2021 07:18 - 14 Apr 2021 07:21
#846682
ZX600E tail light with integrated signals installed.
So rear signals have been removed;
[img
Have had issues with my horn for ages.
Finally found out the horn was tempermental, so bought a new one;
[IMG
Got an Ape bearing clutch pusher as well;
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 07:21 by rstnick.
  • rstnick
14 Apr 2021 07:24 - 14 Apr 2021 07:25
#846683
Rear wheel off for new rubber.
Continental Conti-Gos:
[img
[img
Then a new front,
Hoping it will not cup as bad as the old tire.
Tread pattern being much different, with no alternating small blocks of rubber, should help;
[img
[img
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 14 Apr 2021 07:25 by rstnick.
