  • Page:
  • 1
  • 2
KZ750L4 project 08 Mar 2021 08:45 #844574
  • Claude.
  • Claude.'s Avatar Topic Author
  • Thank you received: 34
Nessism wrote: If you want more forward pegs I've still got my originals, along with the shifter and brake pedal. It's a direct bolt on. I preferred the slightly rearward parts so the switch was made. The peg brackets I've got have been repainted with epoxy primer and urethane top coat. Anyway, they are sitting in a box if you want to simplify and move the pegs forward by a couple of inches for more hip clearance.
I also prefer the slightly rearward position. When I looked at LTD & Spectre shifter, it was only to check it they would be valid donor bikes (but they aren't). But thanks anyway for your offer!
Any opinion about the "mission cover" not supporting the shifter shaft? I'm copying below what I previously wrote. Thanks!
However, I'm less sure about the "mission cover" (called like that on Partzilla). As far as I can see on the parts diagram (Picture below), the way this cover is made, it looks like it does not support the shifter shaft. It does have an oil seal the shaft goes through but looks like there nothing more. I believe the shifter shaft is held only by its both ends and that when the sprocket cover is removed, the shaft wobbles a lot because its outer end becomes unsupported. Do you see it that way?
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
1982 KZ1000J2 (another one!)
2017 Yamaha FZ07
KZ750L4 project 08 Mar 2021 09:31 #844577
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2671
Yup, it's true that the transmission cover doesn't support the shaft. I had forgotten that but confirmed by looking at some parts on ebay.
The following user(s) said Thank You: Claude.
KZ750L4 project 08 Mar 2021 12:14 #844581
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1893
I would do set some bronce selves....
KZ750L4 project 08 Mar 2021 16:29 #844594
  • Claude.
Scirocco wrote: I would do set some bronce selves....
I agree 100%; this was my first option. However, I ignore where I could find some locally and I wanted to process quickly. So, I got some pieces of copper tubing that I'm currently working on. I'll let you know the results when finished.
Thanks again for the comments guys!
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
KZ750L4 project 09 Mar 2021 00:16 #844598
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Copper will be too soft for bushes, oilite bronze is the best...
KZ750L4 project 11 Mar 2021 16:17 #844791
  • Claude.
Does anyone knows what are those frame brackets for? I believe they are for optional engine guards but please confirm.
Thanks!
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
Last edit: by Claude..
KZ750L4 project 19 Mar 2021 19:12 #845249
  • Claude.
Anyone knows about those brackets I posted pics of just above?
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
KZ750L4 project 20 Mar 2021 20:36 #845292
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
Those videos wouldn't show up for me so I couldn't see your wobble.
A pressed in bronze bushing would work best but if the hole is big enough you could try some shim stock.
can you shove a feeler gauge in beside the shaft?
KZ750L4 project 21 Mar 2021 05:56 #845299
  • ghostdive
  • ghostdive's Avatar
  • Thank you received: 118
Yep - they look like the bottom mounts for engine guards.
2001 ZX-6R
KZ750L4 project 28 Mar 2021 11:27 #845675
  • Claude.
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationOne more question: The sight window on the front brake master-cylinder is quite yellowish. On partzilla, I see that it was not available by itself but can it be replaced anyway?
Thanks!
EDIT
I just saw on Ebay that complete unit can be bought for less than $20US... Can those be any good??
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
KZ750L4 project 28 Mar 2021 16:11 #845697
  • Nessism
  • Nessism's Avatar
  • Away
Those masters look good to me.  I'd go for it.
  • Page:
  • 1
  • 2
