'78 KZ1000 Ugly Duckling 30 Apr 2022 12:31 #866430
  • Buzz Nichols
  • Buzz Nichols's Avatar Topic Author
  • Thank you received: 105
Hi Wookie,
I've drilled a little hole in the wheel and epoxied the magnet in there:
1978 KZ1000 LTD
Last edit: by Buzz Nichols.
'78 KZ1000 Ugly Duckling 30 Apr 2022 12:52 #866431
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1821
To every question there is an answer, that'll work
'78 KZ1000 Ugly Duckling 30 Apr 2022 13:23 #866434
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Did that require rebalancing the wheel?  I would think so...
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
The following user(s) said Thank You: 750 R1
'78 KZ1000 Ugly Duckling 30 Apr 2022 18:01 #866444
  • Buzz Nichols
It's an itty bitty magnet and, based on what I've read, has a mass very similar to the aluminum it's replacing. If rebalancing is called for, of course, I'll do that. We'll see...
1978 KZ1000 LTD
'78 KZ1000 Ugly Duckling 30 Apr 2022 18:25 #866445
  • Buzz Nichols
I haven't tried to sew anything since I took a required semester of home ec in 7th grade (some 38 years ago, right when the US education system decided it might be a good idea to teach boys how to feed themselves and teach girls which end of a hammer to grab), so I've been a little reluctant to try upholstery. However, I got a killer deal on a big leather hide, and I've got this beauty languishing at the shop:
So I figured it was time. I found this video invaluable:
I raided my kitchen and used parchment paper to make patterns that I stuck to the back of the leather with 3M spray adhesive:
And I used the same adhesive to stick 1/2" fabric backed foam to the back of the seat top sections, then sewed pleats across them:
Then it was just a lot of sewing. It was what I've heard called "type two fun," the kind of fun that's more or less indistinguishable from suffering. Here's where I'm at so far:
I tried stapling it onto the seat pan—no go. I made the pan from fiberglass and epoxy, and the staples wrinkled up without penetrating at all. I think I'll stick it on with 2-part epoxy and a few tiny self-tapping screws.
The seam at the top of the bump stop wound up off centered. I tried to make up for that by piling up a bunch of top stitching, but that just made it look stupider. It occurred to me my neice does computer aided embroidery for a living, so I think I might get a custom Kawasaki patch to stitch on there.
I''ve got a bunch of leather left over and I'm feeling relatively confident, so maybe I'll make my wife a skirt that matches the seat and see if I can talk her into a cheesecake photo session once the machine is finished.
1978 KZ1000 LTD
The following user(s) said Thank You: ghostdive
'78 KZ1000 Ugly Duckling 30 Apr 2022 20:19 #866449
  • ghostdive
  • ghostdive's Avatar
  • Thank you received: 118
Nothing cooler than something you made yourself. Looks very comfy.
2001 ZX-6R
'78 KZ1000 Ugly Duckling 01 May 2022 01:54 #866451
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Nice work Buzz
'78 KZ1000 Ugly Duckling 01 May 2022 08:54 #866468
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Give credit where it is due...nice job.  Making a seat cover is something I would never venture in to.  I know my limitations and sewing is definitely one of them.  It may not be perfect, but you made it with your own hands!
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
'78 KZ1000 Ugly Duckling 01 May 2022 09:31 #866470
  • Buzz Nichols
Thanks for your kind words. It is definitely imperfect enough that I'll be making a new one at some point, but good enough that I will be making it armed with what I learned from this one, Rather than having somebody who knows what they're doing make it.
1978 KZ1000 LTD
'78 KZ1000 Ugly Duckling 01 May 2022 14:30 #866486
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
You might be able to steam some of those wrinkles out.
'78 KZ1000 Ugly Duckling 01 May 2022 15:03 #866488
  • Buzz Nichols
I kept thinking about everything I didn't like about the seat I made (henceforth "the prototype") and realized that all its issues stemmed from me making simple stuff complicated. Stuff I did wrong:
-Made a full pocket for the bump stop. This meant I couldn't pull the material taut.
-Made it out of waaay more pieces than necessary, which meant I had to figure out lots of seams, plus multiplied my chances of screwing up. On the new version, I only used 4 pieces of leather.
-Glued patterns to the backs of all the pieces. This meant I had all that paper to deal with, and also the glue made everything want to wrinkle and pleat. On the new one, the only glue I used (3M 77 spray) was to stick the foam on the back of the seat top.
-Figured out a stitch length that looked cool for the pleats and then stuck with that. This resulted in pretty weak seams. On the new one, I lowered the stitch length after I did the pleats, plus I did double hems.
-Went to lots of trouble to measure out 1/2" hem margins on everything. This time around, I just drew the seat top and bump stop on the foam with Sharpie and cut it out 1/2" outside of that. Somehow it didn't occur to me yesterday that A: the hem margins don't have to be super exact, and B: I know damn well what a half inch looks like. Once I had done that, it was just a matter of sewing a 3" wide strip of leather onto the seat top and another onto the bump stop, leaving 3" X 3" tails on all 4 ends. Sew the resulting 2 pieces together, and Bob's your uncle.
It still ain't perfect, but I won't be embarassed to put this on my bike:
1978 KZ1000 LTD
The following user(s) said Thank You: Skidmark, ghostdive
'78 KZ1000 Ugly Duckling 01 May 2022 21:02 #866515
  • TexasKZ
  • TexasKZ's Avatar
Nice. That was really quick turn around.
