  • Page:
  • 1
  • 2
The $200 KPZ 750 24 Aug 2020 18:41 #833612
  • Hightower.Ash
  • Hightower.Ash's Avatar Topic Author
  • Thank you received: 0
Hi all, not sure if I'm in the right place, but I was directed here from XS650
Yesterday I found a pair of titled 1984 Kawasaki GPZ 750s for a low low sum of $200.
Did the same kind of deal with my 1982 XS650, got it for $150 and made it work.
These two have definitely seen better days, first step is going to be well, seeing if the engines are free.
I'll post the occasional update and question here and there because as always this is a learning experience.
Last edit: by loudhvx.
The $200 KPZ 750 24 Aug 2020 19:29 #833617
  • Thank you received: 2829
Hightower.Ash wrote: Hi all, not sure if I'm in the right place, but I was directed here from XS650
Yesterday I found a pair of titled 1984 Kawasaki KPZ 750s for a low low sum of $200.
~Ash
I give up. What's a 1984 Kawasaki KPZ 750? Ed
Last edit: by 650ed.
The $200 KPZ 750 24 Aug 2020 21:07 #833620
  • Hightower.Ash
Oops, GPZ.
Lotta K's here
The $200 KPZ 750 24 Aug 2020 22:53 #833624
  • M_a_t_t
  • M_a_t_t's Avatar
  • Thank you received: 41
Pics aren't showing up. Finding cheap bikes seems like something I am incapable of. Good luck with the project(s).
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
The $200 KPZ 750 25 Aug 2020 04:45 #833630
  • Hightower.Ash
Yeah I'm not sure that this forum works well on mobile. I've probably got to upload images and link them
The $200 KPZ 750 25 Aug 2020 05:52 #833632
  • Hightower.Ash
ZX750 A2
According to the Google.
I can't change the typo in the title
GPZ750
The $200 KPZ 750 25 Aug 2020 12:59 #833668
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
  • Thank you received: 250
Im real excited to see what a 100 $ GPZ looks like, they were my every day bike for over 10 years.
The $200 KPZ 750 25 Aug 2020 13:51 #833673
  • Hightower.Ash
Attachment not found
The $200 KPZ 750 02 Sep 2020 18:10 #834252
  • Hightower.Ash
After a few days of toiling I've managed to partially strip all of the delicates out of the carbs.
Fuel mix screws are jammed in, hopefully thats all okay though.
The $200 KPZ 750 02 Sep 2020 18:11 #834253
  • Hightower.Ash
Here ya go, looks like a hot mess
The $200 KPZ 750 02 Sep 2020 19:49 #834266
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Be diligent. It's a diamond in the rough.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
The following user(s) said Thank You: Hightower.Ash
The $200 KPZ 750 03 Sep 2020 04:59 #834273
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
Stuck pilot screws in the carbs is NOT okay. You need to remove them and ungang the carbs to do a proper cleaning job.
In terms of how to remove them, use penetrating oil and heat. And make sure your screwdriver perfectly matches the slot in the screws. Grind a custom screwdriver for a tight fit if necessary. I'd soak the penetrating lube for a few days and apply heat using a torch. Heat and soak, heat and soak. After a few days try turning the screw both ways, eventually working it out. Don't force it or the slot will strip and you will be forced to cut a new slot with a dremel disc.
Last edit: by Nessism.
  • Page:
  • 1
  • 2
