1978 KZ1000-A2 "Barn find" 15 May 2021 06:54 #848463
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Certain roadways used to have "measured miles" on them designated by signs.  The ones in my area were very close to exact distance.  Mile markers on Interstates are close but not exact.  You need to run your bike thru one of those areas and see what you get, or compare with another vehicle.  If your odometer is spot on than your speedo head is the culprit. At that point you have a decision to make, fix the head or leave it and mentally adjust speed.  10% off is quite a bit though.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
1978 KZ1000-A2 "Barn find" 15 May 2021 07:17 #848467
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
On all of my bikes, the odometer has been fine. One way to fix the speedometer is to download a gps speed app on your phone, take along pen and paper, find a lonely stretch of road. Ride at a steady speed and compare the speedometer reading to the gps. I think it is easiest to pick several speeds and take several readings at each speed. Something like an indicated 30, 50, 70. Three or four readings at each will help rule out operator error. You can then take the speedometer apart and remove and reposition the needle.
For example, if the speedometer reads 55 at a true 50mph, gently move the needle to an indicated 55 and mark the mechanism with a sharpie. You will need to mark a moving part with an adjacent stationary part. Remove the needle, align the marks and reinstall the needle so it points to 50.
1978 KZ1000-A2 "Barn find" 01 Jun 2021 21:25 #849462
  • Kaylinator
  • Kaylinator's Avatar Topic Author
  • Thank you received: 74
This evening I replaced the points with a Dyna-S ignition. Simple install. Used the double brown plug inside the headlight to get switched power. My only issue is that the wires on the dyna are about 6" shorter than stock. Had to get a little creative to get them to reach.
I also swapped out the spark plug boots with NGK LB05FP.
It could just be me, but my ear-o-meter would swear it idles better.
I also replaced the regulator and rectifier with a Ricks Electric combo unit. Can't seem to find any details on how others wired theirs in. This one is pretty simple. 3 yellow wired to the existing rectifier plug, two reds to positive, 2 greens to ground.
I didn't get as fancy with the install as I probably should have, but I didn't really have everything I should have at the shop either. But once I had the bike apart, I was kinda stuck there until I got things done.
The first photo below shows how it all looks together. The second photo shows what I did with some of the other wiring out of the way. I'm open to feedback if someone tells me I did this wrong, or inefficiently.
PS. Please excuse the El cheapo bullet connectors.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
The following user(s) said Thank You: BCScott
Last edit: by Kaylinator.
1978 KZ1000-A2 "Barn find" 16 Jul 2021 16:09 #851879
  • Kaylinator
My valve seals have needed replacing from day 1, as I've always had some smoke on downshifts. It's now starting to smoke a bit at idle on occasion too, so I've decided to not wait until winter. It's also a good time to deal with my gooned spark plug holes.
Couple questions:
1. Any special tools I'll need other than a valve spring compressor?
2. Should I lap the valves while in there if I'm not cutting the seats?
3. Anything else I should take a good look at when I have the head off?
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ1000-A2 "Barn find" 25 Aug 2021 00:03 #854311
  • Kaylinator
Wow! Been a while since I posted. Been a busy summer working, planning the wedding (4 days left!) And riding with buddies. I pulled the head a while back and dealt with valve seals. I powered through it in a day, just to prove I could. It was an incredibly long day, and I was completely bagged, but I did it. Stopped short of getting everything synced and running that night tho. I didn't want to push my luck, and felt like I had made my point.
Recently, I started having some really bad surging issues. Actually, I've had surging issues off and on all summer and kept managing to get rid of it by playing with the fuel screws. This time, however, it was really bad. Backfiring hard, sounding like gunfire, scaring small children and grown men alike kinda backfiring. I finally settled on what I'm sure has been my issue all along, which is the choke plunger seals. New choke plungers should be here very soon, if Canada Post ever decides to keep them moving, so I decided to take the opportunity to tear the carburetors apart and bring them to a new local motorbike shop that has a vapor blaster. Carbs came out beautifully, and I almost can't wait until winter to bring him the wheel hubs and motor to do. Almost.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ1000-A2 "Barn find" 25 Aug 2021 09:18 #854325
  • BCScott
  • BCScott's Avatar
  • Thank you received: 97
Good luck with the wedding! Looks like the weather will be perfect. Our son just got transferred to the Bow Island wind farm construction, and is living in the Hat, so we're following the weather quite closely. Carbs look really good.
Back in the saddle and loving it! KZ1000A1
1978 KZ1000-A2 "Barn find" 25 Aug 2021 19:51 #854351
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Carbs look great. Congratulations on getting married.
1978 KZ1000-A2 "Barn find" 26 Aug 2021 05:34 #854364
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 600
Were the carbs still racked when vapor blasted?  Openings & orifices plugged to keep bead out of internal passages?  If not, bead is everywhere inside the carbs, slide crank bearings, etc .
Glass bead has a serious tendency to adhere to the workpiece, be it from surface tension, electrostatic attraction or whatever.  Even after rinsing in detergent water, bead will often still be present.  Sometimes it can be felt as a powdery feeling when running fingers upon the surface.
Bead is almost impossible to see in normal lighting but, bead adhering to a surface can be easily seen as follows:
Place the workpiece in an area of very dim light.  Step back a few paces, 6ft. or so.  Hold a bright light source such as a good LED flashlight just under eye level & shine it at the workpiece.  Any remaining glass bead will reflect the light very brightly.
Best way we've found to remove bead from carb bodies is detergent water in an ultrasonic tank.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The following user(s) said Thank You: Bent Trigger
1978 KZ1000-A2 "Barn find" 18 Sep 2021 10:57 #855451
  • Kaylinator
Sooo... I went drag racing for the first time last night. I'm now fully hooked.
My best reaction time was .001.
My best time was 13.078 at 100.75mph.
I know I can get it into the 12's but the engine is hurt. Cylinder 2 seems it must be scored or something. Entirely possible that valve seals and choke plungers were me just throwing money at the wrong problem, although I certainly don't regret getting those items taken care of.
So now I'll have decisions to make this winter. IF I can get away with a hone and rings I may go that way, but I'm also considering a small big bore kit. My question would be, what is my size limit without swapping out the vm26 carbs? I see Wiseco had a 1045 and 1075 kits. Could those carbs handle 1075, or would I then be looking for some vm28s or larger?
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ1000-A2 "Barn find" 18 Sep 2021 15:28 #855457
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 512
Excellent!! I got hooked 47 years ago! I ran my 72 Suzuki TS 90 Trails bike down the strip!
All the local guys had cars and bikes running! I was 15. Been hooked ever since!
Drags are still cool! Ask Steve Johnson on his new head Suzuki!
And  71yr old Paul Gast running 3.99 ET 1/8 mile’s
Last edit: by z1kzonly.
1978 KZ1000-A2 "Barn find" 08 Nov 2021 15:27 #857683
  • Kaylinator
Winter is coming... The teardown has begun.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ1000-A2 "Barn find" 09 Apr 2022 02:41 #865148
  • Kaylinator
Wowza has it been a while! It's been an incredibly busy winter at work, but the 1000 is FINALLY going back together. I have popped in a few times to check on everyone's projects, and to see if Mikaw has made any momentum on his A4 (spoiler alert:nope).
Had the frame sandblasted and responded all the black parts. The cases, cylinder, head and valve cover are getting vapour blasted while I wait for a few bits to arrive to put it back together. I believe the delivery date on that stuff from Kawasaki is around April 21, so should finally have her back on the road at the start of May.
The wife got me a proper bench polisher for Christmas, so I've been polishing up all the engine covers real nice.
Also, picked up a 1978 KZ400-B1 a week or so ago for $500. It runs, and is mostly all there. A few parts for that bike is also on the way to get it back on the road (speedo cable, master cylinder rebuild, etc) although I'm still trying to sort out someone who can pull that large dent in the tank.
​​​​Now I guess the race is on to see if I can get one of these bikes back on the road before my new Z900RS SE shows up...
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
