KZ1000P conversion. 18 Nov 2018 10:18 #793900
  • Jimbo302
  • Jimbo302's Avatar Topic Author
  • Thank you received: 7
Is there a common rear shock to lower the rear a bit?
KZ1000P conversion. 20 Nov 2018 20:09 #794055
  • Jimbo302
I ordered some sportster 883 shocks and slid the fork tubes up an inch in the tree. That plus this seat looks like it should get the height were I want it.
So far I pulled off all the panels, hard bags and fairing, bled and lubed brake systems, as well as a new battery.
Next up is going through the carbs, new plugs, wires, and carb intakes.
Last edit: by Jimbo302.
KZ1000P conversion. 20 Nov 2018 21:05 #794059
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
The shocks may hit the sprocket bolts or chain. I'd check.
Last edit: by SWest.
KZ1000P conversion. 21 Nov 2018 00:03 #794060
  • Jimbo302
Thanks for the heads up. Ill definitely check fitment when I get them.
KZ1000P conversion. 21 Nov 2018 00:06 #794061
  • Jimbo302
The previous owner had spray bombed this poor thing black.
So tonight it got it's first paint stripper bath.
I'm thinking of ordering a cheapo sandblaster to help finish it.
KZ1000P conversion. 21 Nov 2018 05:29 #794063
  • Jussumguy
  • Jussumguy's Avatar
  • Thank you received: 11
Carburetor cleaner and a soft wire brush should get the paint off. If you sand blast you might make more work for yourself. Be patient and know it will take several sessions to get it all
KZ1000P conversion. 21 Nov 2018 08:01 #794068
  • Ed_in_Miami
  • Ed_in_Miami's Avatar
  • Thank you received: 46
Cool project...!
I will be watching and taking notes.;)
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
KZ1000P conversion. 21 Nov 2018 15:12 #794083
  • Jimbo302
Jussumguy wrote: Carburetor cleaner and a soft wire brush should get the paint off. If you sand blast you might make more work for yourself. Be patient and know it will take several sessions to get it all
Carb cleaner wasn't going to move this stuff. The paint is 1/16th inch thick in some places, completely covering stampings and roll marks.
This is only the first bath, of several.
KZ1000P conversion. 21 Nov 2018 15:28 #794084
  • Jimbo302
Ed_in_Miami wrote: Cool project...!
No, I'm taking notes from your thread.
Yours looks fantastic, where did you get your carb kit?
The following user(s) said Thank You: Ed_in_Miami
KZ1000P conversion. 21 Nov 2018 18:36 #794090
  • Fischer779
  • Fischer779's Avatar
  • My bike runs on the tears of bald eagles
I feel your pain with the "spray bombed" paint. My last project was completely covered in some kind of clear coat.
Sand blasters work great but I have been cautioned not to use them on fully assembled engines. People say the sand will find its way inside, I have never actually seen it happen. Just a data point.
YZ400f "dual sport"
KZ400D
95' Corvette
KZ1000P conversion. 22 Nov 2018 02:40 #794099
  • Jimbo302
Fischer779 wrote: I feel your pain with the "spray bombed" paint. My last project was completely covered in some kind of clear coat.
Yeah, I wish I could just leave it be, as it looked okay, but I can't stand the look and I really prefer natural metal.
Very true, Sand can definitely make it where you don't want it to go if you aren't careful.
KZ1000P conversion. 22 Nov 2018 07:23 #794107
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Soda blasting is an option. Cheaper than a sand blaster but not as effective as or fast.
To speed things up you can use some aircraft paint stripper. It loosens up the paint and once dry the blaster finishes the job. Just don't get it on stuff you don't want to repaint.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
