KZ1000P conversion. 31 Dec 2018 16:34 #795988
  • Jussumguy
  • Jussumguy's Avatar
  • Thank you received: 11
Looks great, nice pipe. How big is the outlet? I’m running stock jetting and it’s right. I’ve got the “street baffle” and I’m close to sea level.
KZ1000P conversion. 31 Dec 2018 17:26 #795991
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Yes, Pipe and bike are looking good.
B)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
KZ1000P conversion. 31 Dec 2018 19:36 #795997
  • Jimbo302
  • Jimbo302's Avatar Topic Author
  • Thank you received: 7
Jussumguy wrote: Looks great, nice pipe. How big is the outlet? I’m running stock jetting and it’s right. I’ve got the “street baffle” and I’m close to sea level.
It's about a 1-1/4" outlet.
KZ1000P conversion. 01 Jan 2019 11:47 #796018
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
  • Thank you received: 87
Thank You, for the input Ive been looking at a setup as yours, But couldn't get any input except salesmen, Ive always run Kerker for so long I don't quite remember a stock pipe sound after 40 years, and Im wanting to put some Town bike bags for a trip to the store for a loaf of bread or something. Ive been to Guam a couple times when in the Navy, What is your quickest time from one end of the Island to the other? I never made it much past the EM club myself.
KZ1000P conversion. 02 Jan 2019 00:01 #796040
  • Jimbo302
9er rider wrote: Thank You, for the input Ive been looking at a setup as yours, But couldn't get any input except salesmen, Ive always run Kerker for so long I don't quite remember a stock pipe sound after 40 years, and Im wanting to put some Town bike bags for a trip to the store for a loaf of bread or something. Ive been to Guam a couple times when in the Navy, What is your quickest time from one end of the Island to the other? I never made it much past the EM club myself.
Its a nice sounding pipe, a lot of bark when you open the throttle.
Not too fast. Traffic usually makes the commute annoyingly slow.
KZ1000P conversion. 02 Jan 2019 00:06 #796041
  • Jimbo302
I adjusted the mix screws and 1,2 and 4 liked 3 turns out , while 3 was happier at 2 out and didnt drag the engine down when turned lower.
The low end power is solid and revs well, but full throttle pulls seem choppy until the rpms rise. I'm gonna have to dig back into the carbs.
Last edit: by Jimbo302.
KZ1000P conversion. 02 Jan 2019 10:14 #796066
  • old_kaw
  • old_kaw's Avatar
  • Thank you received: 269
Jimbo302 wrote: I adjusted the mix screws and 1,2 and 4 liked 3 turns out , while 3 was happier at 2 out and didnt drag the engine down when turned lower.
Lookin good there Jimbo!
Don't sweat the screw settings, but I do look for consistency on their settings. because if there is too much difference, it could indicate other problems such as a partially plugged passage, leaking carb holder, valve not sealing etc.
Mine are probably somewhat like yours though. I don't know, it's been ~ a year since I messed with the carbs . Plenty of other things to screw around with on mine. :-)
I just recently got my OEM spring clamps to replace the missing ones on my intake boots. ONLY 26 bucks for 4 of them from partzilla. What a deal!
1981 Kawasaki Kz1000K1
KZ1000P conversion. 02 Jan 2019 10:37 #796067
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1900
old_kaw
Remove the #stickers and your ss polish will last longer.
Last edit: by Scirocco.
KZ1000P conversion. 02 Jan 2019 14:10 #796076
  • old_kaw
  • old_kaw's Avatar
Scirocco wrote: old_kaw
What poish? lol
It's hibernating. I haven't even looked at the bike in a few weeks. I may get it out next Sunday since a high in the 60's is forecast.
I need to fix this:
Last edit: by old_kaw.
KZ1000P conversion. 02 Jan 2019 14:31 #796077
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Making a simple main stand stop is easy.
KZ1000P conversion. 02 Jan 2019 15:13 #796080
  • old_kaw
  • old_kaw's Avatar
Yep, easy peasy. Fabricating in the cramped, cold 10X10' shed, not so much. Nowhere near as easy as MS painting it in.
KZ1000P conversion. 03 Jan 2019 01:33 #796095
  • Jimbo302
Looks like the No.3 plug boot had come loose on the plug.
I snapped it back in to test out and now it seems like I may have a starter clutch issue. Half the time it spins over fine, but sometimes it makes a loud mechanical spinning "grinding" sound, and doesnt seem to be turning over as well. Time to investigate, I suppose.
I'm going to pick up some new jets to try out as well, after I research the best place to buy them.
