  • Page:
  • 1
1976 KZ750 starting problems 09 May 2018 14:57 #783142
  • MSSJ17
  • MSSJ17's Avatar Topic Author
  • Thank you received: 0
Ok to start off it’s a 1976 KZ750
Traded a pistol for it ($300)
I was told it needed a battery I got it off my buddy. So I got a battery and hooked it up. And nothing happens. My lights come on but that’s all.
The electric start doesn’t do nothing doesn’t even make a sound.
The kick start just acts like it wants to turn over but nothing happens.
I’m new to the motorcycle world and I have no idea what is happening.
I know the plugs are wet, fuel lines work. Battery is right at 13 when I checked it. But nothing happens and I have no idea where to start.
1976 KZ750 starting problems 09 May 2018 15:31 #783147
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1895
Hello and welcome MSSJ17
Some pics of your bike would help to make an overview of your bike condition.
It is very difficult to do a remote diagnostic without pics.
I think you have traded a 750/twin for your pistol.
A lot of reading is necessary to understand the motorcycle technic
kzrider.com/modules/ServiceManuals/Kawas...l%20KZ750%20Twin.pdf
Michael
1976 KZ750 starting problems 09 May 2018 15:54 #783149
  • MSSJ17
I’m sorry here are some pictures.
1976 KZ750 starting problems 09 May 2018 16:19 #783151
  • Thank you received: 2828
Are you pulling in and holding in the clutch lever when trying to use the electric starter? Ed
1976 KZ750 starting problems 09 May 2018 16:25 #783152
  • MSSJ17
Yes I’m holding in the clutch when trying to use the electric start.
The gas is on, the ignition is on, the clutch lever is held in and nothing I push the button and it does nothing
1976 KZ750 starting problems 10 May 2018 06:25 #783166
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2051
First, I saw another thread on this. Please don't do that. It will be easier for all concerned if the whole conversation is in one place.
You really need a genuine Kawasaki factory service manual (fsm). Not Haynes, not Clymer, the real deal. Among other things, it has some good diagnostic procedures in it. For this problem, you should also have a volt/Ohm/amp meter. You can find really inexpensive ones at auto parts stores, Lowes, Ace, et cetera.
When you turn the ignition key on, do lights come on?
Have you checked to insure that the battery cables have good, clean connections at both ends?
Especially check where the negative battery cable attaches to the frame or engine.
Test the fuses. Looking at them can be deceiving as one end of the link can come loose inside where you cannot see. Forty year old solder can get brittle.
A solder connection may have come loose inside the starter switch.
A solder connection inside the ignition switch may have broken loose.
The starter solenoid may be bad, or may not be getting power from the starter switch. That vOa meter will be really handy.
There are more possibilities, but this list should get you on the road to a solution.
1976 KZ750 starting problems 10 May 2018 09:22 #783176
  • MSSJ17
When I turn the key on the ignition the lights do come on but that’s all. And the ground seems fine and the positive looks good. I haven’t checked the starter relay yet.
Also the fuses all check out good.
1976 KZ750 starting problems 10 May 2018 12:01 #783178
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
check the starter relay
early model 76-78
later model 79-82
1976 KZ750 starting problems 10 May 2018 12:50 #783181
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
and here comes the wiring diagrams
Last edit: by Scirocco.
1976 KZ750 starting problems 01 Sep 2020 19:06 #834188
  • BobberDan
  • BobberDan's Avatar
It being a pre 80 would it not have points and condenser
1976 KZ750 starting problems 16 Sep 2020 10:53 #835171
  • jertho
  • jertho's Avatar
  • Thank you received: 8
Yes it does have points and condenser. As said before, you really need a factory service manual. Get one and read through it.
1978 kz750 twin
1976 KZ750 starting problems 03 Oct 2020 10:02 #836103
  • TexasKZ
  • TexasKZ's Avatar
Any update?
  • Page:
  • 1
