CSR1000 Project Build 09 Jan 2017 10:00 #751790
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2101
Bwahahaha!
Looks like you could also sell those on fleebay as butterscotch Lifesavers :whistle:
CSR1000 Project Build 10 Jan 2017 10:32 #751870
  • davido
  • davido's Avatar Topic Author
  • Thank you received: 286
Today I got the carbs all buttoned up and fitted,
and some other bita and bobs done.
and this is where things stand at the minute
Im now just waiting on points cover gasket(s),speedo cable (still),clutch hose and 4 liters of cheap oil.Then its good to go.On schedule for a weekend start-up. Harrr Haaarrr!!!!!!!!!!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: aquaholic
CSR1000 Project Build 10 Jan 2017 11:36 #751877
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Looking great!
B)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: davido
CSR1000 Project Build 10 Jan 2017 12:51 #751890
  • Wiers
  • Wiers's Avatar
Great job David B)
Next time if you need (cheap) Seals,
$10 from my Chinese friend Ali :laugh:
Keep us informed
Eric
CSR1000 Project Build 10 Jan 2017 13:23 #751900
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
yabut those aren't square section o-rings wiers! :whistle:
Last edit: by 531blackbanshee.
CSR1000 Project Build 10 Jan 2017 19:39 #751923
  • aquaholic
  • aquaholic's Avatar
  • 1981 KZ1000 J1
  • Thank you received: 36
WOW your bike looks fantastic !!! I'm doing a rebuild here in the US on a 1981 KZ1000-J1 and just finished the engine rebuild. The frame is ready for install this week. I did purchase a European gasket set for this particular bike and engine and some of the gaskets needed a bit of work before they would fit properly, most notably the cylinder to valve train gaskets and the air reed valve gaskets (I don't think you have these on the European models). Keep up the info and I will load some when I can. I do have 3 carbs from a US model if you need parts lol. I know 3 won't do you much good for your 4 cylinder. How did you get those carbs so clean ?
CSR1000 Project Build 10 Jan 2017 23:56 #751934
  • davido
Thanks Aquaholic and thanks for the offer but my carbs are done and in now.Im pretty sure that the washers I cut will do the job. The carbs will have to come off again later for more tuning but for now they should be good to get the engine running.
Eric,I already have a box like that and I did try o-rings but I didnt have the right thickness for the diameter and as Leon points out the originals are more like washers (straight sides) rather than o-rings (round sides).
As soon as I fill er up, well see if A; The tank repair was a success and B; If the carb gaskets and rings are suitable!
I might need to stand the bike in a big bucket!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 14 Jan 2017 11:23 #752187
  • davido
Well boys and girls, IT LIVES!!!!!!!!
I got it started today.Well chuffed. 2 1/2 years or so building.So nice to press the button and hear if fire up. Fantastic.
On the down side,it still dosnt run yet. It idles perfectly but as soon as I give it throttle it dies.So ill be taking the carbs off again. Any advice on how to set them up would be welcome.( 1070 Wiseco, K&N filters and a Harris 4into1 with a race baffle.).
Other than that Ive got to fit the chain and fart around with the clutch spacing. And the most important part.The stickers!!!!
P.S.So far the tank and the carbs are both sound and not leaking.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 14 Jan 2017 11:24 #752188
  • davido
Attachment IMG_6403.MOV not found
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
    IMG_6403.MOV
CSR1000 Project Build 15 Jan 2017 07:20 #752236
  • Wiers
  • Wiers's Avatar
Congratulations David,
A milestone in the build progress :laugh:
I think I need another week but this gives me a boost.
What kind of spark plugs are u using?
Eric
CSR1000 Project Build 15 Jan 2017 09:33 #752243
  • davido
Thanks Eric.Its amazing how quick it goes once you get to the last bits. I dont know what plugs I have.The tuner fitted them.Ill have a look next week.
Today,I farted around with the clutch.I ended up making a couple of alu spacers to move the MC out a bit.
Everything is fitted and bled now but I cant know how itll work until Ive got the bike moving. So thats it for now as far as the clutch goes.
I also got the chain fitted and tensioned as best I could.still planning to do something with the swingarm at a later point.
Stickers stuck!
Some other bits and bobs done as well and Im pretty much there.I gave it a clean and took some pictures.
So,thats that. Theres still work to do.The clutch and the swingarm but the main thing is to tune the carbs and get it running. Thatll be happening....eventually. For now,Im done. Ive started clearing out the workshop and bringing my tools home. Now Ive got to find somewhere to store the bike until springtime.
Ill post updates as they happen and I thought to maybe do a list of resources that Ive used during the build.Maybe itll be helpful to others.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 15 Jan 2017 14:30 #752260
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
I like it....A nice, well balanced build, well done.... ;)
