My GPz750 Resto-mod (pic heavy) 10 Nov 2013 17:09 #612730
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
  • Thank you received: 117
I set out to finish de-tabbing the lower crossmember today
It seems counterproductive to then make and add back tabs to the lower crossmember, but the original lower suspension and center-stand mounts were in the wrong locations.
Then I tack welded the tab on using my handy dandy jig I made.
I'll fab and tack weld the other lower mount on tomorrow evening I hope.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
My GPz750 Resto-mod (pic heavy) 11 Nov 2013 16:13 #612815
  • StreetfighterKz
Knocked out the other lower tab today.
I also came up with some mock-up adjustable lowering links using an old Zx7 brake stay and some more parts from my 900 build.
Everything looks fairly centered.
Later, Doug
1989 Vmax
My GPz750 Resto-mod (pic heavy) 12 Nov 2013 07:44 #612867
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
coming right along there sir!
The following user(s) said Thank You: StreetfighterKz
My GPz750 Resto-mod (pic heavy) 12 Nov 2013 08:09 #612869
  • Stazi
  • Stazi's Avatar
Friggen sweet. It's interesting that the link go from the shock pivot/lever to the frame and not to the swingarm, like on many other bikes..... :side:
82 KZ1000-K2 LTD
My GPz750 Resto-mod (pic heavy) 12 Nov 2013 08:35 #612871
  • StreetfighterKz
Stazi wrote: It's interesting that the link go from the shock pivot/lever to the frame and not to the swingarm, like on many other bikes.....
Yeah. It make changing ride height a little interesting. I think I have a plan though. My "real" adjustable links should be delivered tomorrow.
Later, Doug
1989 Vmax
My GPz750 Resto-mod (pic heavy) 12 Nov 2013 15:26 #612915
  • StreetfighterKz
I did some brain-storming and came up with an idea for my linkage. I have a length of 1.125"x.125" tube that I cut down to roughly 4.125". I turned the down ends of the tube slightly as well as opening up the inside of the rod ends as manufacturing tolerances are horrible. Next will be getting the tube to the correct length as I only quickly mocked it up to see the feasibility.
Once the tube is the right length, I'll bore the inside to 24mm and 25mm deep so that the stock pivot bearings can be used then the rod ends lightly pressed on. I'm still trying to decide if I need dust seals, too.
Later, Doug
1989 Vmax
My GPz750 Resto-mod (pic heavy) 13 Nov 2013 05:45 #612945
  • 531blackbanshee
  • Vendor
dust seals couldn't hurt.
some thing plastic like butter bowl lids can work well for dust seals.i have a gasket hole punch kit that i use to cut such things out with.
My GPz750 Resto-mod (pic heavy) 13 Nov 2013 09:19 #612966
  • StreetfighterKz
I'm questioning my hybrid design. I think it has some shortcomings though.
If I bore the inside of the connecting tube to 24mm (the needle bearing OD) I'll have only about 0.028" wall thickness at the point where the rod end overlaps the tube. I could weld the two together for more strength but that would weld the bearing inside with the only way to service it is to cut everything apart.
I could also completely open the rod end up to 26mm or so to gain some wall thickness and machine a new tube to fit all the way through the rod end and that would allow the bearing to be inserted from the end and then weld all the way around the tube and rod end.
Any suggestions?
Later, Doug
1989 Vmax
My GPz750 Resto-mod (pic heavy) 13 Nov 2013 14:18 #612999
  • 531blackbanshee
  • Vendor
"I could also completely open the rod end up to 26mm or so to gain some wall thickness and machine a new tube to fit all the way through the rod end and that would allow the bearing to be inserted from the end and then weld all the way around the tube and rod end."
i believe that is the way i would go.
My GPz750 Resto-mod (pic heavy) 13 Nov 2013 15:17 #613001
  • boatdrinks
  • boatdrinks's Avatar
  • Thank you received: 54
Paint scheme flows nicely. I'm diggin' it!
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
My GPz750 Resto-mod (pic heavy) 13 Nov 2013 16:16 #613005
  • StreetfighterKz
I got my lowering links today. Not exactly what I was expecting but I can make them work for me.
I machined the tube to accept the stock linkage bearings EXCEPT I accidentally flipped the tube around and machined too much out of the end that was a perfect fit for the bearing already. :doh: So looks like I'll have to make another tube which I count as more practice. I'm going to make a Version 2.0 but until then the links will be a prototype used for mock-up.
Later, Doug
1989 Vmax
My GPz750 Resto-mod (pic heavy) 14 Nov 2013 16:56 #613083
  • StreetfighterKz
Finished up my linkage and made sure everything played nice together and it does.
Next up is designing and fabbing the upper shock mount.
Later, Doug
1989 Vmax
