Over the last few years I've been wanting to do a full tear-down and rebuild of a motorcycle. My old Yamaha 650 is slowly dying, but others convinced me the bike wasn't worth the effort to salvage. Recently a friend told me to look in to the KZ900. Loved the bike, but finding something to work with seemed a bit out of my price range, not to mention the parts are harder to find. No problem, the KZ1000 still has the same look and will work just fine for me. I prefer the older bikes, but wanted to do a little refresh on the look.
After searching around for a few weeks, I ran across a potential deal on craigslist. The seller said the starter was shot, but the engine had recently ran. Good deal for me, I looked it over and talked him down to $500 for what I thought was a complete bike. After getting it home and really starting to tear into it, I realize the starter doesn't work because the step-down gear pin has torn out the holes in the case. The seat and gas tank, and forks are wrong for this model, and all of the seat and rear fender brackets have been cut off. Half of the wire harness has been cut and spliced at some point, there are brackets missing or badly chopped and rigged... But hey, it appears to have a new battery in it!
OK, I can salvage this. I have a good starting point, let's see what can be done. I started hitting up Ebay for parts, and get a crankcase from a police bike sent to me, which appears in great condition. I also manage to pick up the correct rear fender (inner and outer), and a starter cover.
In the meantime back on craigslist again, and a couple weeks later I can't believe what I've found -- someone has chopped the front end off another '81 KZ and is selling the remainder. I pick this up for $250, and now I have a second complete engine, a rear frame with all the brackets, other brackets which were missing, and a nearly pristine LTD wiring harness. Of course this now means that I have duplicates of ALL of the ebay parts I had previously picked up. Ah well, I'll pick out the best of the lot and sell the rest.
Now I have a plan... I will cut and splice the two frames together, salvaging what I need from each. The fuel tank on the original bike is banged up quite a bit, but I now have the frame mounting tabs from the J and K models, broadening my choices for finding a replacement tank.
I also discover that there are several differences in the wiring harness between models, mostly in the turn-signal cancelling circuits. Surprisingly, the parts that need changed out are also parts I already need to replace -- the left side handlebar switches, and the odometer. I find there is one part of the new wiring harness that has been chopped and spliced, but again luck is with me and I have that same section on the original bike without any cuts. So my completed electrical system will be completely intact.
At this point, I have acquired quite a pile of ebay parts to replace pieces that are broken or missing -- horns, front fork crosspiece trim, handlebars, left-side switches, front master cylinder, odometer, a spring for the center-stand, gas tank cushions, and some after-market smoked turn signals... I also found an LTD seat in excellent condition, and just today I received a fuel tank that is far more than I had hoped for -- not a dent on it and barely a hint of rust inside. I also have a lead on a pair of side covers, which will complete all of my major purchases. I received a set of 4-to-2 pipes recently from another member here to replace the 4-to-1 that was on the bike. I also need to find a new meter bracket, and I'm trying to find a style of mirrors that I like.
Total spent on the project so far... around $1700 (and I might be able to recoup about half that when selling the extra engine and other parts). Considering everything except the turn signals are original parts and not reproductions, I'm pretty happy with the price.
I have been playing with paints, and found a candy color I like. Using a metal-flake undercoat, I am using a burnt-orange color that really shines in the sun! I would like to paint the tank, side covers, and both fenders with this color. The engine and pipes will be either flat- or satin-black, and the rest of the frame and wheels will be gloss black. There will still be some silver showing -- the forks, brake rotors and chain, possibly the covers on the carbs.
My plan is to get started next week tearing down the first bike, then cutting and re-welding the frame pieces. Hopefully I can get the frame cleaned up and powder-coated before the cold weather sets in. The engine will be a project for this Winter, taking my time and getting advice on any upgrades that should be done while it's apart. Once the warm weather hits next Spring, I can work on painting the candy color parts, then get everything put together and start learning how to tune this engine.
