Better Than Nothing---The rebirth of a Superbike. 06 Sep 2016 11:33 #741285
  • Dr. Gamma
  • Dr. Gamma's Avatar Topic Author
  • Thank you received: 670
750 R1 wrote: Thanks Gamma, I saw the pics of the frame mod but was wondering what you did to the seat, did you basically just bend it a bit, or cut stretch and weld..? I am amazed at how much it changes the look of the bike, much more aggressive... I love it... ;)
Just worked with the bare seat pan. No welding or cutting of the pan. Just a little bending and reshaping to get it to fit the top frame rails. It now just sits right on the frame rails, and mounts with two 6mm studs to the frame.
1986 RG500G 2 stroke terror.
Better Than Nothing---The rebirth of a Superbike. 06 Sep 2016 11:36 #741286
  • Dr. Gamma
rstnick wrote: Congratulations on the Suzuki's win Doc.
They are a rare ride.
I know of three and one frame that buddies have.
Get well soon Doc.
B)
I like the old bevel drive Ducati in the back ground in the one photo!!!! That was the same model, and color of the very first Ducati I ever saw in real life. It was at the 1974 AMA road race at Road Atlanta in the spectator area by the esses that I saw it!!!!
Better Than Nothing---The rebirth of a Superbike. 06 Sep 2016 11:40 #741289
  • Dr. Gamma
mjg15 wrote: Got one too! I had a new one in '87 that I sold in '91. Bought ths one recently, needs sorting, but I'll get to it...
Yea, it took me like a year to get mine sorted out after I got it back together. Picky little sucker on jetting!!!! I wish I had zippers on the carbs instead of bolts and screws. But when I got the jetting right, what a difference in power!!!! Lean is mean.
Better Than Nothing---The rebirth of a Superbike. 13 Sep 2016 15:01 #742106
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
B)
This one?
A buddy owns that, or restored it.
He seems to like the Ducatis a lot, and has a number of them, among other classics.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Better Than Nothing---The rebirth of a Superbike. 15 Sep 2016 15:18 #742387
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
  • Thank you received: 36
Dr Gamma, PHENOMENAL bike!!! Dang it looks good!
2000 ZRX 1100
1976 KZ 900- Daily Driver
Better Than Nothing---The rebirth of a Superbike. 13 Oct 2016 12:15 #745154
  • Dr. Gamma
Here is a short summary of whats all been done in the building of my Kz1000 Superbike road racer.
All major frame modifications done by Rob North and Pierre DesRoche back in 1979. This chassis is basically a copy of the bike that Reg Pridmore won the 1977 and 1978 AMA Superbike Championship on. Chuck Parme used basically the same bike to finish the highest placed privateer in the 1980 AMA Superbike Championship.
An oversize steering neck with TZ750 roller bearings is used, and has been relocated to put the front and rear wheels in alignment. Neck has also been repositioned rearward to put more weight on the front wheel, and it has about 2 more degrees of fork angle. KZ650 triple trees that have less trail are used to quicken up the steering. Double fork tube clamp bolts have been added to lower tree to increase fork rigidity.
Swing arm has been modified by DesRoche by cutting open, and welding in some internal bracing. An extra tubular 4130 moly hoop has also been added to bottom of swing arm. An oversize swing arm pivit bolt with matching swing arm inner sleeve are used, and mated to a honed to size mounting bosses on frame.
Frame has extra tubular bracing added through out the whole frame. This triangular bracing along with the DesRoche aluminum motor mount plates with ream-fit oversize bolts ties the motor to the frame making it one strong non-flexing structure. All worthless brackets, and tabs have been removed from frame for extra weight savings.
Yoshimura/Kayaba road race forks are used along with a 2.50X19 inch magnesium Morris mag. Brakes are 13 inch Kosman full-floating rotors with a pair of reworked Lockheed dual piston calipers mated to a KZ1000S1 master cylinder with a 11/16 piston. Earl's Supply -3 braided steel lines tie the whole brake system together.
Rear rim is a 3.50X18 inch magnesium Morris mag. Along with a Hunt plasma-coated aluminum brake rotor, and a KZ1000A brake caliper.
Light weight rearsets are fabricated using KZ1000S1 components. Mark II fuel tank has been reworked to use dual Z1R petcocks. This setup will allow the very last ounce of fuel to be picked up from tank!!! Custom fabricated gauge bracket with a rare KZ1000S1 road race tach. Vintage Yoshimura 1/8 turn Superbike throttle is used to open up the Keihin CR33 carbs. Custom fabricated Bassani Superbike pipe for the ultimate in cornering clearance is used.
Bike can be made street-legal with very little effort. All the provisions are there to add lights and charging system for street use. A under 440 pound street-legal KZ1000 makes a pretty nice street bike!!!
Current motor in bike;
KZ900 cases and covers are used for their lighter weight over similar KZ1000 parts.
KZ1000 cylinder block and head are used for this motor.
Lighten and polished KZ900 Falicon Supercrank with polished stock rods.
Moriwaki Engineering 73mm two ring cast pistons.
Cylinder head work by Yoshimura R&D with 37.5mm intake valves.
Yoshimura Super Bonneville cams running on Yoshumura KZ650 style shim buckets with lighten Yoshimura valve spring retainers.
Lighten and balanced Falicon clutch basket with O.E.M. clutch plates, H/D springs, and a needle bearing clutch pusher.
Transmission is a factory Kawasaki close ratio road race item. It comes from the factory fully undercut.
Andrews Products kickstart gear is fitted so the stock kickstarter can still be used with the close ratio box.
Motor has no provisions for electric start. Even the starter motor mounts have been removed for weight savings!!!
Stock diameter M.T.C. H/D Golden Studs are used so not to impede oil flow to the head.
Modified oil pump to eliminate any chance of oil aeration.
Earl's Supply 10 row oil cooler and plumbed with Earl's Supply AN8 braided steel lines and fittings.
Keihin CR33 carbs with the AMA mandated 31mm restrictors still installed are used.
Kal Gaurd Gun Kote coating has been applied to the complete motor, and covers to aid in the reduction of engine temperature.
Last edit: by Dr. Gamma. Reason: added more!!!
Better Than Nothing---The rebirth of a Superbike. 13 Oct 2016 14:19 #745174
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
love this bike! a true survivor!!
thanks for posting,
Better Than Nothing---The rebirth of a Superbike. 13 Oct 2016 18:05 #745188
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
Wow! this bike deserves to be nominated for bike of the month/year.
Better Than Nothing---The rebirth of a Superbike. 14 Oct 2016 07:32 #745211
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 2007
mopguy wrote: Wow! this bike deserves to be nominated for bike of the month/year.
Hmmmmmmmmmmmmmmmmm :unsure: :unsure: :unsure:
Ya think :whistle:
Better Than Nothing---The rebirth of a Superbike. 25 Oct 2016 10:49 #746180
  • Dr. Gamma
CR's
Better Than Nothing---The rebirth of a Superbike. 28 Oct 2016 16:36 #746401
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2127
+1
mtbspeedfreak wrote: Dr Gamma, PHENOMENAL bike!!! Dang it looks good!
Better Than Nothing---The rebirth of a Superbike. 30 Oct 2016 12:45 #746575
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
:ohmy:
Super...
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
