z650 c4 09 May 2007 12:55 #138600
  • OnkelB
  • OnkelB's Avatar
  • Thank you received: 80
No problem, you´re welcome. But I´d still be very interested to hear what your engine number is - I never knew there were any 650 engines that had both hy-vo (multiplate) cam chain and kickstart. Like I said I thought the first 650 with hy-vo chain was the F2 (no kickstart).
Btw, on the bottom right side of the cylinder block there´s a number, does it say 652 ccm?
Post edited by: OnkelB, at: 2007/05/09 17:41
77 KZ 650 B1, 82 GPz 1100 B2.
z650 c4 10 May 2007 00:21 #138770
  • yggy
  • yggy's Avatar Topic Author
  • more wrenching than riding!
  • Thank you received: 0
Ok OnkelB (u must have belgian in ur roots if u call urself this :P, onkel means uncle in belgium :P)
anyway.. ill check the engine number tonight and post it.. i don't have it with me here at work..
and yea it says 652ccm on the cilinder block :)
btw I was a bit dissapointed when opening the engine and suspecting HUGE piston heads.. these look like lawnmower cilinders! :P (i might need to explain that this is my first attempt in engine rebuild :P)
1980 EU-z650 c4 one of the few C's around..
z650 c4 10 May 2007 03:19 #138785
  • OnkelB
  • OnkelB's Avatar
Also in Denmark, that´s where I´m from - no connection to Belgium as far as I know.
The reason I asked about the ccm markings was because I was wonering if your engine was an old style 650 bottom end with a 750 (or late style 650) crank and top end.
z650 c4 11 May 2007 12:23 #139213
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
The C4 must have been a transition year where the High-Vo chain was used and the kickstarter is still present. I see the alternator cover is similar to the '80s models as well.
Any idea why the kickstarter was ditched on later models?
Post edited by: rstnick, at: 2007/05/11 15:25
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
z650 c4 13 May 2007 14:26 #139734
  • yggy
E're we go..
Pictures update!
the engine number special picture for OnkelB! :)
some elbow grease and some rattlecan action
before:
after:
looks in pretty good nick still after 84k kms
theres that hyvo chain!
pretty clean cilinder heads (after cleaning :P )
although some grubble is visible on the bores, they are nice and smooth still.
652cc for ya
the engine..(where my father in law dropped some bits in the other day :P we where just joking about how stupid it would be to drop stuff in there ,LOLOL)
Post edited by: yggy, at: 2007/05/13 17:39
z650 c4 22 May 2007 04:21 #142328
  • yggy
Small update, still waiting on some parts to start the rebuild of the engine with fresh seals..
Replacing the shocks to be able to rebuild the Koni shocks
Jep, real KONI's
They look scruffy though, will have to do some work on them
In the meantime look at these pretties, bought on Ebay for 10 dollars
Post edited by: yggy, at: 2007/05/22 07:22
z650 c4 23 May 2007 19:51 #142951
  • kzwolfsr
  • kzwolfsr's Avatar
  • Thank you received: 16
Brings back memories from December
Original man of the Caribbean
z650 c4 23 May 2007 19:53 #142952
  • kzwolfsr
  • kzwolfsr's Avatar
pics
z650 c4 23 May 2007 19:56 #142955
  • kzwolfsr
  • kzwolfsr's Avatar
another
z650 c4 23 May 2007 19:58 #142956
  • kzwolfsr
  • kzwolfsr's Avatar
another? Last pic I promise
z650 c4 25 May 2007 21:31 #143563
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
  • Thank you received: 13
kzwolfsr wrote:
...Last pic I promise...
NO! More pics! MORE PICS! ...I like this project.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
z650 c4 13 Jun 2007 03:52 #148935
  • yggy
Nice Pictures Kzwolfsr!
Well after a few weeks of waiting for parts and waiting for my father in law to feel a bit better after a motorcycle trip went sour before his eyes in the "black forest, germany" (a bloke from the gang was driving too fast and missjudged the corner, slammed into an upcomming car and died on the tarmac) So dad in law didnt feel like doing alot for a few, and rightfully so.. :(
Now, back on track, we put in a new chainguide, fixed the rear caliper (the bike "rolls" quite nicely now before it didnt want to move that much..u had to put in some extra weight) spraypainted some parts of the frame (will do bigger overhaul later when i get another bike)
fixed the valve clearence, was 0.0 on 5 of eight valves.. NOT good. bought 5 shims for 60 dollars :P rediculous price if u ask me. But i had them straight away..
bolted the engine back to the frame, added the "surface" cleaned carbs (will do those after the summer with a total rebuild, but now i wanna RIDE! :P)
started up last night, battery a bit low so used the kickstart, 3 kicks and there it was..
VROOOAAAAAAAAAAAAAAAAAAAAARRRRRRR 3000 revs.. (choke was on full :) )
awsome feeling, that, after having the engine open for the very first time, i allways believed that the bike would explode after ignition :P (yep not much believes in me own skillz yet :P )
gonna do a test run tonight, just around the block.. Will try to get the missus to film me :P
and ill get some more piccies..
editmode: WEEHEEE finally got my Clymer Book, one day too late for the main overhaul (i had to use the crappy haynes book) My god the Clymer's soo much better ..
Post edited by: yggy, at: 2007/06/13 06:57
Post edited by: yggy, at: 2007/06/13 08:51
