81 KZ750 Regulator/Rectifier Wiring
- Kc650
24 Jun 2024 11:15 #901241
by Kc650
81 KZ750 Regulator/Rectifier Wiring was created by Kc650
First time poster here… wiring a KZ750E2 motor on a 78 KZ650B frame/harness and have run into an issue with the R/R wiring. I have an aftermarket R/R with 6 wires total - 3 yellow, 1 black, 1 red/wht, and 1 brown. Based on the wiring diagram, I have the red/wht going to the hot side of the starter solenoid. For some reason, when I connect the battery, the brown is hot - basically full battery voltage. Hoping someone can advise on what might be causing this. Thks!
- Thank you received: 2806
24 Jun 2024 12:20 #901245
by Nessism
Replied by Nessism on topic 81 KZ750 Regulator/Rectifier Wiring
How about contacting the manufacturer of the aftermarket R/R, and asking them how to wire it? Typically, the brown wire is a voltage sense wire, attached to a switched power source.
- gd4now
- Denco where did you go?
- Thank you received: 429
24 Jun 2024 12:26 #901246
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic 81 KZ750 Regulator/Rectifier Wiring
Question, where are you testing the brown wire for voltage? Is it connected to the rest of the loom or not connected to anything but still showing battery voltage? As I understand it on the 650 loom the brown wire caries power to most of the system once the key switch is turned to on. The regulator uses this as a sense wire to determine what it needs to do, how much to pass on to the electrical system/battery and how much to shunt as it is not currently needed. So as I said above, if the brown wire on your need RR is not hooked up to anything and you get full battery on it them something else is going on. If it is hooked up to a brown wire on the loom and the key switch is off then something else is wrong. If the key switch is on and the brown wire from the RR is connected to brown on the loom it should be at battery voltage.
1977 KZ650 B1
- Kc650
24 Jun 2024 12:32 #901247
by Kc650
Replied by Kc650 on topic 81 KZ750 Regulator/Rectifier Wiring
Good idea. Looking into that now…
- Thank you received: 2053
24 Jun 2024 12:54 #901248
by Scirocco
Replied by Scirocco on topic 81 KZ750 Regulator/Rectifier Wiring
AFAIK the 77/78 KZ650 R/R wiring loom has an one or three phase stator with a field coil magnet wiring (no permanent magnet rotor).
Please check your stock main electric wiring enviroment first.
- gd4now
24 Jun 2024 13:09 #901251
by gd4now
1977 KZ650 B1
To the best of my knowledge the field coil system was only offered on the 77 model year 650. In 78 it changed to a single phase permanent mag system. The 750 motor came stock with a 3 phase permanent mag system. Now something I did not mention is the bike in question may have a build date of 78 but still be a 77 model year He is using a 3 phase RR system which unless it was intended to be used on a 3 phase field coil system should work correctly with the 750 motor setup..
1977 KZ650 B1
