  • Page:
  • 1
  • 2
New guy, odd application 24 Oct 2023 05:37 #890886
  • MJinCO
  • MJinCO's Avatar Topic Author
  • Thank you received: 0
I'm new here and I have a really different application by your normal standard.  In fact I basically flunked motorcycle school years  ago.  However, I have a Ocelot MkIII race car that dates back to 1971 and it has a 1982 KZ1000J2 motor in it and I never been dealing with bike motors and this one needs serious help at the moment.will have some really odd questions.  I'll try to post a picture or two when I figure out how.
Last edit: by Street Fighter LTD.
New guy, odd application 24 Oct 2023 06:52 #890892
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Welcome to KZRider
Kool Kar
New guy, odd application 24 Oct 2023 06:59 #890894
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1789
Welcome from the UK, that looks like a lot of fun
New guy, odd application 24 Oct 2023 07:12 #890896
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 370
Welcome to the fun!  That is an interesting looking machine. Bet when it is running right it is loads of fun to drive!
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
New guy, odd application 24 Oct 2023 08:33 #890901
  • Moderator
I wonder if they allow  turbo's
Make it like a mini 917  can am car
New guy, odd application 24 Oct 2023 08:34 #890902
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
New guy, odd application 24 Oct 2023 08:47 #890904
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2678
Very cool!  What's the top speed on that bad boy?  Does it go fast enough to take advantage of the aero downforce wings?
New guy, odd application 24 Oct 2023 11:30 #890906
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 431
Uber cool toy!
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
New guy, odd application 24 Oct 2023 12:42 #890911
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
My dad's '74 Z1
'00 ZRX1100
New guy, odd application 24 Oct 2023 17:33 #890917
  • MJinCO
Bought it last December.  Haven't had it out yet.  Completely rebuilt the suspension, rod ends are regarded as wearing items all 28 of them.  New brake MC's and lines, rebuilt calipers and coil over shocks.  I sort of educated guessed as to what to set the suspension to for camber, toe in etc.  This older suspension design has pretty bad bump steer by today's standards. Getting ready to take it out I check the spark plugs and #4 was just wet with no fire.  First replace coils with A1 2.4 ohm ones for better spark.  Checked compression and 123 about 120, #4 60 With oil 120 went to 150 and #4 to 120. So probably bad rings.  Checked valve clearances and 2 exhaust at about .05mm cold which is probably too tight as they should be at the top of the scale.  The 234 exhaust cam lobes have a yellow tint so got pretty hot.  Where can I get shims for the shim on top of bucket so I can loosen up the exhaust valves to .15mm.
New guy, odd application 25 Oct 2023 11:12 #890948
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
You may be able to reduce the "bump steer" by playing with the position of the steering rack (higher or lower) if you can get it so the track rods are "flat" at the mid-point of the suspension travel the effect will be reduced as the change in length through the "arc" will be minimised
Last edit: by Wookie58.
New guy, odd application 25 Oct 2023 13:11 #890954
  • Moderator
I wanted to buy a D Sport Racer about 40 years ago. Regret not pulling the trigger on it
Would have used it as a club racer here in Michigan at Waterford Hills .
Like a  large go kart   . I was going to turbo it as a club racer it would be  wicked.
  • Page:
  • 1
  • 2
