Restoring a 1976 Z900 A4
  • dancragin
  • dancragin's Avatar Topic Author
Re: Restoring a 1976 Z900 A4
28 Jan 2021 16:34
#842594
Yes I upgraded the charging system, new stator and the updated regulator. I also changed over to the Dyna ignition and ran the power to the coils through a relay so it would not have to power through the ignition switch. I ended up replacing all the wiring harnesses, fuse box and flashers with new, as well as the switch gear and ignition switch.
I am having the production gauges rebuilt. It nice to know so much is available for these bikes at a reasonable cost.
I did a Suzuki Rotary and it was really hard to find parts.
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
28 Jan 2021 16:43
#842595
Please keep us in tune!! more pics please, its all too cool.
  • dancragin
01 Feb 2021 13:14
#842803
Here are a couple pictures of my progress. Its crazy how many detail there on a build you want just right. I'm sure it will need quite a bit of sorting when done.
I installed a dyna igniton and found the way the coils mount differs from the stock coils and will require a custom bracket.
Does anyone make these?
Also anyone now how to post pictures right side up. They dont transfer upright.
  • hardrockminer
  • hardrockminer's Avatar
01 Feb 2021 15:27
#842808
I'm surprised your coils won't fit the existing brackets. They should. Can you show photos?
  • cb900f
  • cb900f's Avatar
01 Feb 2021 16:34 - 01 Feb 2021 16:34
#842812
dancragin wrote: Also anyone now how to post pictures right side up. They dont transfer upright.
Before posting, open the pictures in something like MS Paint - rotate to proper orientation and save over top the original - that'll fix the orientation issue. If you use a more advanced photo editing app, it's liable to maintain the goofy orientation even after saving.
Last edit: 01 Feb 2021 16:34 by cb900f.
  • Mikaw
  • Mikaw's Avatar
01 Feb 2021 17:46 - 01 Feb 2021 17:50
#842817
dancragin wrote: Here are a couple pictures of my progress. Its crazy how many detail there on a build you want just right. I'm sure it will need quite a bit of sorting when done.
I know this oh to well. I have touched, cleaned, Vblasted, plated, re-chromed, polished, painted or powder coated every nut, bolt, washer, and bracket if it was salvageable. Bought NOS when possible, if not the best of the aftermarket. Soaked rubber in brake fluid to restore. Investigated part numbers, serial number, and dates. Laced rims, rebuilt wiring, degreased, and regreased. I have built a bike (well not completely yet) from the frame out. Call me crazy but I’m loving it. Can’t wait to see it finished and gleaming in the warm summer sun.
Good luck, I hope yours turns out exactly the way you want it.
Here’s a fresh order of NOS from Partzilla just arrived today!
Last edit: 01 Feb 2021 17:50 by Mikaw.
  • Kaylinator
  • Kaylinator's Avatar
02 Feb 2021 12:00 - 02 Feb 2021 12:01
#842850
Mikaw, I'd be interested to hear how your soaked rubber bits hold up. According to this video, they will eventually sweat and start firming up again.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
Last edit: 02 Feb 2021 12:01 by Kaylinator.
  • dancragin
02 Feb 2021 13:29
#842851
I figured out the coils. I just had them orientated wrong.
Gosh its nice to someone else as excited as me about building a KZ!
I will keep posting.
  • Polish
  • Polish's Avatar
02 Feb 2021 14:11 - 02 Feb 2021 14:17
#842854
What is the benefit of Dyna ignition? I mean, they are not cheap, so why over stock of its working properly?
Thx and sorry for my ignorance
JL
1979 Honda CB400T Cafe Racer (current ride)
1982 KZ750 LTD (current project)
Last edit: 02 Feb 2021 14:17 by Polish.
  • Kawnut
  • Kawnut's Avatar
02 Feb 2021 15:30
#842862
I too am surprised they won't fit. I am restoring a (1982) GPZ 7500 & replace stock with Dyna & had no issues.
  • Mikaw
  • Mikaw's Avatar
02 Feb 2021 15:40
#842866
Pros and Cons. But I feel the pros win.
Pro-Is pretty much set it and forget it.
Con-Some will say points typically won’t fail instantaneously as a electronic module will so with the Dyna S you could be stuck on the road. True it could happen but I personally haven’t heard of any such events.
Con- Cost outlay
Pro-Over the life how many sets of points will you replace
Then there is all the stuff I really don’t understand completely, dwell timing which helps coil saturation, no change in dwell like in points as they start to wear.
Loudvhx is the electronic ignition expert. He can fill in the rest.
  • Kawnut
  • Kawnut's Avatar
02 Feb 2021 15:48
#842869
Dude, I am jealous!! HA! Looks outstanding, wish you nothing but good luck! Hope my project turns out close to how yours looks.
