paints... cans beware...
  • requiem
  • requiem's Avatar Topic Author
28 Nov 2006 08:52
#95625
cans suck i do believe... I painted my bike with automotive grade rattlecans... looked fabulous until I put gas in it, and it promptly turned white. I used about 4 coats of primer and about 8 coats of paint and 3 or 4 clearcoat's on top of that... did I do something wrong? It looked pretty for about a day, haha.
Oh, and howdy everyone, I feel like a numbnuts... I didn't have KZR bookmarked and I kept typing in www.kzr.com which came up as 'for sale'... I have been distraught for about a month because my most favorite website was gone, haha. I'm dumb.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
28 Nov 2006 09:46 - 03 Dec 2008 14:05
#95639
del
Last edit: 03 Dec 2008 14:05 by JMKZHI.
  • ambergrismooon
  • ambergrismooon's Avatar
Re: paints... cans beware...
28 Nov 2006 09:50
#95640
Sorry.......couldn't help it.....:blink:
  • Pterosaur
  • Pterosaur's Avatar
28 Nov 2006 11:06
#95658
For the most part, but they're not all created equal.
Not sure exactly what that means. Got a brand name to go with it?
....looked fabulous until I put gas in it, and it promptly turned white. I used about 4 coats of primer and about 8 coats of paint and 3 or 4 clearcoat's on top of that...
Been known to happen, but again, there could be a number of causes.
What primer did you use? What color did you paint the tank? Whose clear did you use?
There's a whole range of things that need to be identified before the true nature of the problem is becomes apparent.
Sounds like you used a light toned primer and painted a light base/solid color like yellow/green/red and the primer bled into the paint. But that's just a guess for the moment.
Start with outlining brands and colors for each of the stages - primer/color/clear.
...did I do something wrong? It looked pretty for about a day, haha.
Obviously, but welcome to the club - you're not the first.
By definition, a rattlecan paint job is certainly not up to the standard of a staged application, but done right, it can come out looking good - and be fairly tough. We need more info on precisely what steps you took though...
  • requiem
28 Nov 2006 11:27
#95666
Not sure on the brands, I bought them at Auto Zone. it was a olive drab primer and black paint. I know how to paint, it is not an application problem... i can paint with normal guns or cans... unless it's bleeding through or something.
  • Pterosaur
28 Nov 2006 11:41
#95674
A possibility: was the O.D. primer a *zinc chromate* type? I'm no expert on Auto Zone paints...
The possibility is that the O.D. primer and the black didn't agree with each other.
The notion with branding rattlecans is that it's generally a good idea to stick with one brand from primer to clearcoat - grabbing cans from different brand shelves is a good way to get neck-deep in multi-colored goo...
Bin there, dun that. ;)
  • pyxen
  • pyxen's Avatar
28 Nov 2006 15:24
#95735
I rattlecanned my tank earlier this fall, and its been great - even with gas spilled on it now and then when filling up. B)
Not a white mark anywhere.
Sounds like luck of the draw to me :(
84 KZ550-F2 LTD
93 ZR550-B4
  • Tim G
  • Tim G's Avatar
08 Dec 2006 22:51
#98391
Did you paint on a day w/ high humidity?
Back when bodyshops painted w/laquer{same as rattlecans} moisture in the air would get trapped in the paint film,causing a white haze.
Sometimes you could buff it out,sometimes it would reappear...
  • requiem
09 Dec 2006 08:13
#98426
that's very possible. but i didn't notice the white until the gas got on the tank... and it is a mark going down the side from the fill cap.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
09 Dec 2006 08:51
#98442
So what brand and type of paint did you use that can stand up to fuel?
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • RonKZ650
  • RonKZ650's Avatar
09 Dec 2006 08:54
#98444
It only lasted a day? That's a new record even I wouldn't have dreamed of. Normally a repaint will look good for quite a while, sometimes even a couple of months.
  • requiem
09 Dec 2006 08:56
#98445
haha it lasted longer than a day, but it wasn't long, week or two.
