GPZ 750 R1
- Michel3007
Re: GPZ 750 R1
17 Nov 2023 21:04 - 17 Nov 2023 21:05
Hi Howard,
Are you sure about that ? One of the ebay pictures shows the fairing installed on a Gpz750.
What make you think it's not proper ? Are the headlight dimensions different on the 550 and 750/1100?
Cheers,
Cheers,
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
Last edit: 17 Nov 2023 21:05 by Michel3007.
- howardhb
- God, I trust
Re: GPZ 750 R1
17 Nov 2023 21:50 - 17 Nov 2023 22:15
The 550 fairing is shorter (front to back) i.e. the headlight on the 550 is closer to the triple clamp / shocks, and narrower. Also, the lower mounting holes are closer together on the fairing, so my brackets will not work.
550
1100
And, the position of the indicators is totally different.
Yikes, my machines need a wash
550
1100
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
Last edit: 17 Nov 2023 22:15 by howardhb.
- howardhb
- God, I trust
Re: GPZ 750 R1
17 Nov 2023 22:56
I looked at that Ebay fairing again... it may or may not be a 550 fairing, however, it is certainly not the same as what I designed my brackets to suit...
'81 GPz 550 D1
- GPZenthusiastic
Re: GPZ 750 R1
21 Nov 2023 08:42
Hi there ,
Not sure if I'm too late into the topic.
Ebay US has a KZ750 R1 , seems OEM, in decent shape .
Not cheap , u$s240 + shipping .
Mine is an aftermarket one and it does fit fine , Quality is acceptable I only had to make the holes on the bottom .
Brand is Dennis KIrk but again U$s 260
Both have mounting brackets
- Michel3007
Re: GPZ 750 R1
21 Nov 2023 11:06 - 21 Nov 2023 11:06
Hi,
Never too late to join the party !
Thank you for the info, do you have the link ? I can't find it on ebay...
Otherwise, the UK seller in the link I posted replied and told me that he could modify the fairing to look like the original one (the side follows the curve of the screen, cf the picture below)
I think I will try it and report.
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
Last edit: 21 Nov 2023 11:06 by Michel3007.
- GPZenthusiastic
Re: GPZ 750 R1
21 Nov 2023 21:15Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- Michel3007
Re: GPZ 750 R1
21 Nov 2023 22:32 - 21 Nov 2023 22:33
Well that went fast... I went to see it 2 seconds ago and while I was typing a message to the seller, the fairing went... too bad, it even had the brackets.
If anybody out there has an original fairing in good condition with brackets, give me a shout
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
Last edit: 21 Nov 2023 22:33 by Michel3007.
- Mcdroid
- Gone Kwackers
Re: GPZ 750 R1
22 Nov 2023 07:15
You mentioned that the fairing with he brackets was gone...it is still listed on eBay, if you are interested. What makes that fairing attractive is that it has some of the rare brackets and apparently, the even rarer windscreen gasket.
Michael
Michael
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- GPZenthusiastic
- Michel3007
Re: GPZ 750 R1
23 Nov 2023 01:50
Yeah that's weird it disappeared from my searches for a moment. I sent a message to the seller but still waiting for a reply. A bit expensive though, if you factor in the shipping and import taxes... I'll see what he says as he might not accept to ship outside of the US.
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
- GPZenthusiastic
Re: GPZ 750 R1
25 Nov 2023 10:45
Yes, it is expensive.
Also right about shipping.
It has original brackets but you need the bracket that attaches to front forks . I may still have those , not positive .(I had to make different once for my inverted forks)
It has ,as well , original screws and knots for windscreen , 4 metal 3 plastic.
In my experience, new parts will show up on ebay , BUT it takes a long time.
- Mcdroid
- Gone Kwackers
Re: GPZ 750 R1
25 Nov 2023 11:06Yep, rare parts do show up on eBay and you have to develop patience...checking daily or several times daily for months or more.It has original brackets but you need the bracket that attaches to front forks . I may still have those , not positive .(I had to make different once for my inverted forks)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
