Who Makes The Kawi Replacemnt Frame Vin Tag Stickers?
- Gray17
Re: Who Makes The Kawi Replacemnt Frame Vin Tag Stickers?
19 Feb 2023 07:25 - 19 Feb 2023 08:03
Sorry youve misunderstood my request, i dont need to alter my vin or frame number, but obviously the EPS file will be set to the other bikes number, before printing the sticker i need to edit the file to change it to my frame number, otherwise ill end up with a sticker with wrong frame number on.
Last edit: 19 Feb 2023 08:03 by Gray17. Reason: Add info
19 Feb 2023 08:29
Understand. Personally I’d just have someone that knows all the little difference in them print them. I’ve bought several and they are cheap. As mentioned here I was told there are 14 different tags just within one model. The file you get might not be what you need.
- Gray17
19 Feb 2023 09:29
Yes did see that on previuos post, however here in UK we dont need the sticker legally, as mine was a US import it was onboard, obv since having frame repainted its a bit beat up, was just thinking a new one would freshen it up. Also better to have something then nothing is my train of thought, so whilst offeredgrabbed the opportunity, do take your point it may be not identical to current one but as thats virtually unreadable, id be happy either way.
19 Feb 2023 09:51
I know Rick is from or travels to the UK and If I’m correct Kidkawie just moved there. Again why reinvent the wheel.
- Gray17
22 Feb 2023 21:06
Thank you i would very much appreciate a copy of the EPS file, as PM not working, how do we contact each other. Didnt want to post email address on forum?
thanks
thanks
