Prepare for sandblasting
  • gordone
  • gordone's Avatar Topic Author
24 Nov 2017 10:27
#775014
I`m going to deliver my frame for sandblasting and paint next week.
I have inserted temp. bolts into the threads and I have used nuts over the treads to protect them.
I asume these is smart ?
But what do you do with the steering opening on top and button ? It must also be protected ?
I was thinking making some small woods pieces and use a long thread axle to keep them on place ?
But then will the wood also protect paint on the edge ?
I have attached what I mean, example from the to side, but was thinking doing the same on the button also ?
Project:
  • Nessism
  • Nessism's Avatar
Re: Prepare for sandblasting
24 Nov 2017 11:09
#775016
I wouldn't do anything for the steering neck. The races will get pitted but that's no loss since you should install new bearings anyway.
I'd be sure to tape off the VIN label if you are trying to save it. Be careful though, because the tape you use will likely remove the clear mylar over the top of the label. You might want to talk to your powdercoater about how best to protect the label.
  • gordone
24 Nov 2017 12:04
#775019
Nessism wrote: I wouldn't do anything for the steering neck. The races will get pitted but that's no loss since you should install new bearings anyway.
I understand, I can see there a metal ring attached to the frame, and the bearing is gliding on these metal ring, I should replace the metal ring also? So I`m let the metal ring be there under blasting and paint, then I can remove the ring after at the frame will me nice and clean on the inside for new ring and bearing?
I don`t have any VIN label, only the frame number :(
Project:
  • Nessism
  • Nessism's Avatar
24 Nov 2017 13:16
#775023
No metal ring that I'm aware of. Did you check the parts fishe? Are you talking about the outer bearing race? If so, those need to be replaced (fun task...not).
  • gordone
24 Nov 2017 13:49
#775024
Nessism wrote: No metal ring that I'm aware of. Did you check the parts fishe? Are you talking about the outer bearing race? If so, those need to be replaced (fun task...not).
hehe based on "fun task.. not" I think we are talking about the same thing :)
They are nice to remove before blasting and painting?
Why is not the bearings and the outer bearing race not on the diagram for the fork?
www.partzilla.com/catalog/kawasaki/motor...ont-fork-81-82-h1-h2
Project:
  • Wozza
  • Wozza's Avatar
24 Nov 2017 14:13
#775025
there on the frame page
www.partzilla.com/catalog/kawasaki/motor...h1/frame-81-82-h1-h2
1982 KZ550H1
  • gordone
24 Nov 2017 14:47
#775029
ahh.... :)
I just the picture bad or ? the bearings I have (2) don`t looks like these?
MIne looks like these, please see attached photo.
Project:
  • Wozza
  • Wozza's Avatar
24 Nov 2017 15:22 - 24 Nov 2017 15:24
#775031
Yours have been upgraded to tapered roller bearings .they are better than the old bicycle type.
You shouldn't have a problem getting a kit for your bike if they need replacing.
1982 KZ550H1
Last edit: 24 Nov 2017 15:24 by Wozza.
  • gordone
24 Nov 2017 15:32 - 24 Nov 2017 15:33
#775032
Wozza wrote: Yours have been upgraded to tapered roller bearings .they are better than the old bicycle type.
Ahh okey... then I have some questions :)
1. Must I measure the bearings manual to be able to order new ones?
2. How can I check what condition they are into? maybe I can reuse them?
3. Please see attached photo, there a ring (between the two red circles) and these ring is coned, and the bearings is gliding on it,
I think it`s identical on the bottom also, because the bearing is the same for top and bottom. Maybe the ring is 1,-1,5cm with/deep, same with as the bearing...
I guess I need to protect these ring under sand blasting ?
OR can I just replace the ring, easy ? I think I will let it stay ?
Project:
Last edit: 24 Nov 2017 15:33 by gordone.
  • mopguy
  • mopguy's Avatar
25 Nov 2017 05:35 - 25 Nov 2017 05:36
#775042
I doubt you will be able to save your VIN sticker, so take a few good pictures of it and then you can have them reproduced by a member here that reproduces the VIN stickers, at the moment I am not sure of our member log in name, but it may be Kidkawie, if not I am sure other members will know.
Last edit: 25 Nov 2017 05:36 by mopguy.
  • bluej58
  • bluej58's Avatar
25 Nov 2017 06:20
#775044
If done right your tapered bearings should last a life time, mine have over 75,000 on them and no problems.
If they are greased well and have no rust on them they should be fine.
78 KZ1000 A2A
  • gordone
25 Nov 2017 08:45
#775048
bluej58 wrote: If done right your tapered bearings should last a life time, mine have over 75,000 on them and no problems.
I understand, thank you.
Talking with the painting i will block the opening top and button and he will blast the frame and then manual take what is left when the blocking is removed.
Project:
