Replacement decal sets
  • GKBO
  • GKBO's Avatar
  • Saving old"dead" bikes
Re: Replacement decal sets
02 Mar 2014 07:17 - 02 Mar 2014 07:18
#623857
Mcdroid wrote: Reproduction Decal/Diablo has really changed since I last purchased from them...they apparently no longer offer any GPZ750/1100 decal sets. Guess the market is changing.
Yeah noticed that as I'm going to be in the market for the 82 GPz 750.Drat!
Last edit: 02 Mar 2014 07:18 by GKBO.
  • kzz1king
  • kzz1king's Avatar
02 Mar 2014 08:36
#623865
Thank you. By trimming the paper for the upper stripes will it make placement (location) difficult? I hadplanned on going with a solid black but think the graphics would look great on black.
Wayne
PaintWorkz wrote: The 74 decals will go on easy except for the upper yellow tank stripes. For those trim all the paper away within a 1/16 " of the yellow and be sure to use the soap and water mix and start from the back of the tank. On the upper 75 white stripes I ended up pulling all the paper off and laying them on and stretching them like pin stripping tape, and then cutting the ends to match the black stripe with an X-acto knife.
kzz1king wrote: I want to do the total nightmare one :laugh: I am thinking the white and yellow graphics used on the 74 green ones on black bodywork.
Wayne
quote="PaintWorkz" post=623714]Diablo and Reproduction is the same company. Very good quality decals. Decals are sometimes tricky to apply. When you have a flat decal on a piece of flat paper going on a curved surface it wants to get wrinkles. Think of applying a 12 inch square piece of contact paper to basketball........you are going to struggle with it. It all depends on what tank the decals are going on. A flat sided 78 Z1R was easy.... 76 KZ900 not too bad....75 Z1 and 75 H1 was a nightmare.
There is a decal guy from the UK on eBay with super low prices.... he uses pictures from Reproduction decals and sells you total junk!
[/quote]
Home built KZ1000 turbo setup
  • mopguy
  • mopguy's Avatar
02 Mar 2014 17:28
#623941
I have been using Reproduction Decals/Diablo Cycle for quite some time. Their products are top of the line, I highly recommend them, they are very friendly and their customer service is second to none. They are about a two hour bike ride away from me, so ocasionally I go for a ride there to pick up my stuff.
  • PaintWorkz
  • PaintWorkz's Avatar
03 Mar 2014 04:08
#623987
kzz1king wrote: Thank you. By trimming the paper for the upper stripes will it make placement (location) difficult? I hadplanned on going with a solid black but think the graphics would look great on black.
Wayne
The instruction will say to trim away excess paper. Using masking tape you need to lay out some reference points for the the stripes to line up to first. When you have the decals you will see the issue of wrapping a flat sheet decal around a curved tank..... before you pull the paper off the sticky side of the decals. Just follow their instructions and take your time and they will come out OK.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • kzz1king
  • kzz1king's Avatar
03 Mar 2014 09:40
#624012
Thanks again, appreciate the help and I am starting to get the picture now!
Wayne
Wayne
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
03 Mar 2014 10:29
#624023
We have a digital department where I work...(banners, vinyl truck lettering, etc.) I am considering making my own stripe set, but regarding any vinyl graphics application, on a surface that is curved on 3 planes, you might find it helpful to use a blowdyer on high heat to slightly soften larger stickers as you work across...tends to make the vinyl "drape" a bit...more forgiving...but go slowly, precisely, and gently...lightly soaped water under, and a soft plastic squeegee on top are your friends! fwiw!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • ramtough_63
  • ramtough_63's Avatar
03 Mar 2014 12:03
#624030
The newer wrap materials( higher end vinyl) has microscopic air vents within the material and doesn't use application tape and is (semi) repositionable. you can position it dry pop it loose and reposition it doesn't actually adhere until you apply pressure 3M & Orafol are a couple that Make this vinyl and higher end shops offer decals made of this
a general clue is the statement "no application tape needed"
as with any curved surface the contour should be cut into the vinyl the straight line wont look straight on the backing paper. even the contoured pieces that are curved wont lay real easy with the application tape (paper or clear covering)
ask your vinyl guy if he is using Rapid Air or similar vented vinyl
if your supplier is using the same materials he was 3 yrs ago he is lightyears behind the innovation in Vinyl
I have a friend who stays on the cutting edge (no pun intended) of vinyl graphics
the old days of application tape and a little soap mixed with water wet applications are no longer necessary its mostly patience and not getting ahead of the application.
The good news is if the back says orajet 3M orafol or other name brands it doesn't matter what cheap cutter cut it. it will be of decent quality
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • kzz1king
  • kzz1king's Avatar
04 Mar 2014 14:46
#624168
Great info Ram , thanks man.
Wayne
ramtough_63 wrote: The newer wrap materials( higher end vinyl) has microscopic air vents within the material and doesn't use application tape and is (semi) repositionable. you can position it dry pop it loose and reposition it doesn't actually adhere until you apply pressure 3M & Orafol are a couple that Make this vinyl and higher end shops offer decals made of this
