tank dish & and new Kawi green paint 77 KZ1000
- vick074
Re: tank dish & and new Kawi green paint 77 KZ1000
10 Apr 2012 04:12DoubleDub wrote: Can you share what color you used? It looks a lot like the modern green on the Ninjas.
Believe it or not, it's straight Kawasaki lime green.
Not the modern green on the newer Ninjas.
- Zedone
12 Apr 2012 01:44
Wow, very nice work. Can you explain how you got the tank lines so nice? Did you take the tank apart at the seam lines to make the knee dents. Also do have a link for your rear shocks. Thanks Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- vick074
12 Apr 2012 03:23 - 12 Apr 2012 03:30
the piggyback shocks are all over ebay and a pretty cheap, I'll be upgrading to Ohlins when I can afford it. Here's a link to the ones I got.
Thanks! It started with just drawing a template on the tank where I wanted my guidelines to be. Then using a nylon hammer started hammering from the center working the way out in a circular motion. The reason the lines are so clean are from body filler and sanding/ filler/ sand to get the perfect lines before final primer and paint. For the seams I just used a cresent wrench to slowly work my way around the tank folding bit by bit under, until they were all flat. finished with a little hammering. Note for anyone doing this, make sure that you fold the seams all the way around flat to the inside at the front of the tank where the rubber tank mounts slide in. I made the mistake of not folding them far enough, so when I got my tank back from my painter I realized that I didn't have clearance to get past the folded seams. So the post mounts are getting cut off and Nuts are going to have to be welded onto the frame to allow the rubbers (with screws through em) to be adjustable. That way I can screw them all the way in to get clearance. then screw the rubbers out enough so they fit snug into the slots in tank.Zedone wrote: Wow, very nice work. Can you explain how you got the tank lines so nice? Did you take the tank apart at the seam lines to make the knee dents. Also do have a link for your rear shocks. Thanks Doug
Last edit: 12 Apr 2012 03:30 by vick074.
- Zedone
13 Apr 2012 06:52
Thanks Vic.
1977 KZ1000A1
- Drooz
14 Apr 2012 14:57Love what you've accomplished so far Sir!!
I'm having a tough time figuring what tail and light that is. :blush: Looks wonderful!!
Can you enlighten me?? :lol:
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
- vick074
14 Apr 2012 23:07Thanks, It's actually a 70's KZ tail just hacked off at the end, with a integrated LED taillight installed.
- BlackZ1R
- Kawasaki in my blood
15 Apr 2012 16:21
Very nice work. Like that look and what you've done to the tank and rear section.
Is that a 100/90 or 110/90-19 on front?
Can you come up with the color code for the green?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- BlackZ1R
15 Apr 2012 16:46Patton wrote:Old Man Rock wrote: ...Keep them images coming....
Attachment omrarmorchromeman.jpg not found
:laugh: :laugh: :laugh: Patton, you ain't right ole son!!! :lol:
Kawasaki
- vick074
15 Apr 2012 16:53I believe it's a 100/90-19 as for the paint code, I have a message in with my painter and I'll get back to you when I get it.BlackZ1R wrote: Very nice work. Like that look and what you've done to the tank and rear section.
- BlackZ1R
16 Apr 2012 01:12vick074 wrote:I believe it's a 100/90-19 as for the paint code, I have a message in with my painter and I'll get back to you when I get it.BlackZ1R wrote: Very nice work. Like that look and what you've done to the tank and rear section.
10-4. Look at it an let me know for sure what size it is and tire it is. ThanKZ.
KC
Kawasaki
- RayK
20 Apr 2012 13:35 - 20 Apr 2012 13:36
That Kawasaki Green looks incredible on this bike! Good job! I've been debating what to paint my '79 KZ650 D2, and really wanted to do her up in this green or the Candy Lime green. Some folks say "great color, but not for a vintage bike" - I have to disagree. That looks simply amazing!
Ray
Ray
Last edit: 20 Apr 2012 13:36 by RayK.
- vick074
20 Apr 2012 14:14sorry this took so long BlackZ1R, been a little busy. The front wheel is a Metzeler Marathon ME 880 100/90-19. And painter says it's called "lime green" but can't get a code due to legalities with Kawasaki?? sounds kinda weird to me, but I guess Kawasaki is very protective of their paint codes.BlackZ1R wrote:vick074 wrote:I believe it's a 100/90-19 as for the paint code, I have a message in with my painter and I'll get back to you when I get it.BlackZ1R wrote: Very nice work. Like that look and what you've done to the tank and rear section.
KC
