what is the best cleaner for aluminum?
  • wdizard
  • wdizard's Avatar Topic Author
12 Aug 2011 23:31
#468727
I want to clean the light rust on my kz1000 engine. Does any one have experience with this?
Thanks Guys!
Greg
  • MFolks
  • MFolks's Avatar
Re: what is the best cleaner for aluminum?
12 Aug 2011 23:47
#468734
Aluminum can oxidize, making it look old. A product called "Nevrdull" is a cotton fiber with a cleaning/polishing compound in it available at most auto parts stores: www.nevrdull.com/
The following user(s) said Thank You: wdizard, Sienna050406
  • wireman
  • wireman's Avatar
13 Aug 2011 01:55
#468751
mothers regular aluminum polish is my favorite B)
  • Chaotic Reason
  • Chaotic Reason's Avatar
13 Aug 2011 05:09
#468759
The best aluminum cleaner is elbow grease of course! :woohoo: I crack me up... Na, seriously, x2 on what they said. ;) Both work great. But a Dremel and a polishing wheel couldn't hurt!
Michael
1980 KZ1000 shaft drive
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
13 Aug 2011 10:02
#468773
I found a polishing wheel attached to a drill along with a soft metal cutting/polishing compound (I use Porter-Cable light polishing comp. #4) works best. Getting at the cooling fins is a pain, but you can use a Dremel with a polishing wheel for that. I tried the Autosol Aluminum polish without much success. Have I use the Nevrdull with great results, but mainly for chrome having light rust. It also takes some elbow grease. For sheer speed and results, a wheel/compound combination seems to work best on aluminum.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • martin_csr
  • martin_csr's Avatar
Re: .
13 Aug 2011 10:50 - 22 Jan 2013 03:15
#468782
Last edit: 22 Jan 2013 03:15 by martin_csr.
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
13 Aug 2011 13:56
#468808
If you have a good compressor, soda blasting (using baking soda)is another option. I have read many posts on KZR regarding soda blasting. Plan on trying it myself but haven't got around to it. I think I saw a post by patton describing the process and how to set one up. Lots of nice looking results posted on here. Seems to be better suited for cases, cooling fins and so forth. Where the aluminum has more texture. But as I said I haven't tried it yet. So better informed individuals here can give you better insight.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • steell
  • steell's Avatar
13 Aug 2011 16:43
#468826
If it's badly oxidized, then the spray on Mag wheel cleaners that say "Not for use on coated wheels" will clean it right up. Just be sure to wash the motor thoroughly with water after use.
I forget the name of the acid that's in it, but it's the same stuff they use on aluminum fuel tanks and wheels on big trucks at the truck washes.
And then you polish :P
  • Jack
  • Jack's Avatar
14 Aug 2011 11:32
#469008
Ragman's Polish from Norwalk Ohio. Never found anything that cleans aluminum like this stuff.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • Polar_Bus
  • Polar_Bus's Avatar
16 Aug 2011 12:10
#469368
martin_csr wrote: Semichrome. Mothers mag wheel & aluminum cleaner. BlueMagic. Autosol. Maas. Metal Gloss. MetalWax. The last two are mentioned as being used in the aircraft industry. A ScotchBrite pad might be good to use if the oxidation is bad.
Do an internet search for Best Aluminum Polish.
I use Eagle One cast mag wheel cleaner and a scotch brite pad. Does an AMAZING job ! Be fore warned, there is a high concentration of acid in wheel cleaners ! Work a small area for like a min., then quickly hose off the cleaner. To prevent further acid staining, after I am done I rub the aluminum with penatrating oil. Here's some pics of my shiney clean GSXR frame after a day's cleaning :
[IMG
[IMG
[IMG
Bikes:
'84 GPz1100
'06 HD Fatboy
  • gwolever
  • gwolever's Avatar
19 Aug 2011 18:28
#470109
I have been working on polishing various engine covers/parts. Here are some finished covers, cam chain tensioner and cap, and breather cover. I have some other parts on my paint table drying.
Attachment 019.JPG not found
I used some aircraft paint remover first (careful with this stuff). Then wet sand (800 grit automotive paper) with some soapy water. Then I used my bench buffer with a stiff buffer and black polishing compound first. Do this until you get rid of all the spots and piece shows a nice shine. Wipe the piece down with paint thinner and rag to get all black compound off. Then I use the loose buffer with white compound. This I used with very little pressure for a good and even mirror shine.
It has taken me 3 days of my vacation to polish several pieces from the engine, but how else am I going to spend my vacation anyway since the engine is pulled from the frame at this time.
Good luck and have some fun with it (helps to have a few beers in the garage fridge).
1982 KZ1000 CSR
  • gwolever
  • gwolever's Avatar
19 Aug 2011 18:38
#470114
Oh. I forgot to add that I cleaned them again with paint thinner to get rid of the white compound. then washed with soap and water. Made sure they were good and dry, then sprayed them with high temp engine clear coating.
1982 KZ1000 CSR
