Kreem gas tank woes
- Pterosaur
Re: Kreem gas tank woes
14 May 2006 17:27
guavatone wrote:
Probably just odds n' sods flakes of rust that previous flushes didn't wash out.
Anything you get out of it at this stage is one less thing to clog a filter.
I'd pony up a nickle to have seen the inside of that tank before you started the Panama Canal treatment on it - that had to be *one rust-infested mother*. Reading your posts, I got the impression that only paint was holding it together in the first place.
Really.
There were strange flakes on metal after my last blow dry - is this avoidable or does it matter?
I hope this is it and I can rejet this baby and do some ridin'![]()
Really.
- guavatone
14 May 2006 17:54
No, it actually was not bad at all until it flash rusted and the whole inside was covered. I think I messed up one of the steps to bring this rust about. I think it was when I let the muriatic and water solution sit overnight. Oh, and then my bottom holes seeped overnight, then rain and damp weather in North Jersey and my garage has a leaky roof. all of these seem to be the worst conditions. and my tank sat for 2 years in this garage 1/3 full of fuel before this treatment.
From what I can make the metal is very solid but I am no expert.
1 hour to go
oh, BTW the flakes were grey-metal and not rust color
Post edited by: guavatone, at: 2006/05/14 20:55
1 hour to go
- Pterosaur
14 May 2006 18:11
guavatone wrote:
It *WAS* that bad. It was *ALWAYS* that bad.
And here's why:
If you wanted to write a *TEXTBOOK* on how to make a tank rust itself into a pile of red dust on the floor, *there's Chapter 1*.
Well, since you had already phosphoric-treated the tank, any rust flakes still in there would have turned a nice grey-metal shade by the time they came out...
Follow KZSCI's last intruction, button it up, fill it full of gas (and KEEP it full of gas) and go ride...
And here's why:
...then rain and damp weather in North Jersey and my garage has a leaky roof. all of these seem to be the worst conditions. and my tank sat for 2 years in this garage 1/3 full of fuel before this treatment.
oh, BTW the flakes were grey-metal and not rust color.
- guavatone
14 May 2006 19:48
Well done is done! the only color other than grey is the bottom seam that has a light red line which I think I'll have to live with. I thought about working on some outside/under tank areas but I am sick of these chemicals....and high enough...hopefully this nany seals up for the road since o-rings are a bit larger.
I misunderstood the mushroom coment I think, so now what you are saying is that the rust never leaves but kind of goes into remission from these treatments.
next up, re-jetting and riding. Many thanks to ptr and KZCSI for the advise and encouragement.
- Pterosaur
14 May 2006 20:04
guavatone wrote:
Pretty much. Just keep it full of gas. If it's gonna sit for an extended period, add a fuel stabilizer additive. That'll slow the rusting process to next to nil. For *years*, if you stay at it.
Actually, I was saying it all along. But yep, that's pretty much the case. Rust is a *microscopic* process that occurs at the crystaline structure level of the metal. You can get %99.99 of it, but you'll play hell getting at that last 1/100 of a %. All you can do is slow it down.
You're welcome...
.... Many thanks to ptr and KZCSI for the advise and encouragement.
You're welcome...
- guavatone
14 May 2006 23:42
sorry, but my woes will continue with "McGuyver this sensor" about my leaky sensor plate ooooooooohhhhhhhhhhhhh nnnnnnnnnnnnooooooooooooooooooooooooooooooooooo!
