Low cost basecoat/clearcoat? Is it possible?
- Nelson
08 Oct 2010 17:26
Anyone know a source for some lower cost auto paint?
I painted cars and bikes 20 yrs ago so I know the benefits of the good stuff. My latest trips to the pro paint store are scaring me. I'm planning 3 or 4 colors with a clear coat. Many hundreds of dollars! Even PPG's low end Omni is brutal.
Today I thought I was going to buy a simple one stage paint for my frame, but a quart of omni with hardener and reducer is almost $100!! And that's 5 or 10 times more paint than I need.
So I'm reluctantly considering using spray cans for the frame and Omni for the body work. I suppose I'll have to use Duplicolor engine paint on the frame in order to resist gas, etc.
For the body stripes - What if I used spray cans for the color coats and then Omni clear on top?
Any other ideas?
Any other ideas?
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- camaroguy
Re: Low cost basecoat/clearcoat? Is it possible?
08 Oct 2010 17:43
Iwas just at the paint store the other day. got a price for nason base clear with all redusers everything for 73.00
- Nelson
08 Oct 2010 17:46
Is that only the clear, hardener and reducer? or colors also?
- otakar
08 Oct 2010 18:39
NAPA will most likely be the cheapest. Personally I only use PPG DBU base cote and "Concept 2002" I have some other PPG clears such as "Omni AU" I can sell you enough to do your bike both clear and hardener. It is a good hi volume production clear. That will save you a lot of money. You should only require about a half pint to do the whole bike.
buyat.ppg.com/refinishProductCatalog/Ser...c5-b523-6b9f1f9277e5
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Nelson
08 Oct 2010 19:00 - 08 Oct 2010 19:15
Thanks otakar
Are u offering to sell clear, hardener and reducer only?
What I need is this:
For the body-
3 colors of basecoat in very small quantities.
1 clear with hardener and reducer. 1/2 pint? or pint
For various parts it would be nice to have some one stage black, silver and red with hardener and reducer. But I may end up doing those things with spray cans.
For the body-
Last edit: 08 Oct 2010 19:15 by Nelson.
- z1kzonly
08 Oct 2010 20:26
I don't know if you live in a rural area, or a town or city.
I live in Buffalo, NY.
You should check with a local collision supply warehouse.
See If they have samples from a supplier. Like a quart of clearcoat and a half pint of hardener. For a 4 to 1 system.
Urethane clear is the only way to go. They make products that dry in 5 minutes.
Or go to a local collision shop and ask for a cup of sugar LOL!
Paint stores, Home Depot, sell empty pint or quart cans, get a couple of empties and ask to buy some product at a local shop.
My next project is GM, White Diamond Pearl, The Caddilac color!
$158 dollars!!! for a PINT!!! of mid coat,the pearl, metallic.
White base, midcoat, then clear!
I started with laquer 30 years ago. Now you have to be a chemist with a degree to paint. I have put mixed clear in my pyrex cup, then in the microwave oven to warm it like tea. Then run out to the garage to spray it, with a pot life of only 1 hour.
Wonder why I was divorced 15 years ago, parts in the dishwasher, painted parts in the oven, chemicals in the microwave!
Here is about a $1000 worht of material!
Yes, you can use paint product for years after you buy it! I have! As long as it does not freeze or gel up.
Got to love it!
Got to love it!
- PLUMMEN
08 Oct 2010 20:33
otakar wrote:
i was gonna suggest napa also,make sure they give you fresh materials thoughNAPA will most likely be the cheapest. Personally I only use PPG DBU base cote and "Concept 2002" I have some other PPG clears such as "Omni AU" I can sell you enough to do your bike both clear and hardener. It is a good hi volume production clear. That will save you a lot of money. You should only require about a half pint to do the whole bike.
- otakar
09 Oct 2010 02:55 - 09 Oct 2010 02:56
Nelson wrote:
I buy base cote dependent on what I paint, so I don't have any color selection. But I do have clear because I buy that in much larger quantities and have that on hand. So I figured that I could save you a few bucks and offer you at least that much. I have a FedEx has-mat account and can ship these in the US. I have clear, hardener, and reducer.
Thanks otakar
For the body-
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 09 Oct 2010 02:56 by otakar.
- mjg15
09 Oct 2010 04:07
I paid $16/pint for the base coat that I just used on my wheels. It was from NAPA, Crossfire was the product line, but I can't recall the brand.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- camaroguy
09 Oct 2010 08:00
The 73 dollars included all hardener and redusers for 1 pint base and 1 pt clear. I thought that was pretty good. I was expecting at least 100
- Oliver
09 Oct 2010 12:02
Try a home paint store like Sherwin Williams. I'm planning on using a black epoxy maintenance enamel. It's designed for industrial metal railings and such.
As far as the body parts go. I have tried lost of Auto paint But I have always had the best luck with Dupont base clear.
I almost jumped over the counter at a PPG salesman because the book was wrong, the color didn't match and they didn't want to make it right.
Valspar is weird paint. I used the auto paint and It had a funny satin like finish, acceptable but weird. I used the home paint and it had the same weird type of finish.
I thought that was pretty odd.
Things I currently own
1983 kz550ltd owned 10 years
1982 kz1100a2 just bought as winter project
1967 vw beetle 1775cc first car owned 25 years
- z1kzonly
09 Oct 2010 12:32
Valspar paint, it was probally base coat.
Which needs clear coat.
I like Dupont chromabase best, it mixes 50/50 with basemaker.
