Carbon Fiber Bodywork
- testarossa
Re: Carbon Fiber Side Cover
08 Jul 2010 22:43
Junction, TX happened to me. Its crazy. 5 minutes from I-10 and you can't even get the internet on my cell phone which gets the internet anywhere. I have a few good pictures of the vacation which I will post for you guys.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
09 Jul 2010 00:19
Fair enough, the pics should be interesting, hope you had a good time
So, back to my mold. After spending a couple hours and going through a few sheets of 1500 grit sandpaper, I was rewarded with this:
It turns out it's a PITA to get into those tight little corners with sandpaper and removed all the primer. I might need to hire an asian girl with tiny hands to sand those spots :laugh: The sanding opened up the surface of the mold a little more, exposing some more pinholes as well as revealing two larger defects
FRANKEN Z!
- porchev914
09 Jul 2010 00:23
One was just a small "chip" in the gelcoat at first, but when I tried to open it up a bit with a razor blade, a much larger area revealed itself to be compromised
This is located on the curve at the bottom of the sidecover
FRANKEN Z!
- porchev914
09 Jul 2010 00:37 - 09 Jul 2010 07:53
The other defect was located in the top rear corner of the sidecover
I used a razor blade to trim back the thin gelcoat until the defect areas were surrounded by thicker, solid gelcoat. I'll patch these tomorrow, along with the other smaller pinholes. Those of you familiar with autobody work know that once you're done sanding body filler, it's not uncommon to have pinholes left that need to be filled. I was taught to open up the pinholes with a razor so that they were cone shaped holes, making them easier to fill. I tried to do this with these pinholes, but the gelcoat it a bit too hard and brittle, so I just picked at them to open 'em up a bit more. Should do the trick ok. This is a good illustration of the benefits of spraying multiple coats of gelcoat, allowing each coat to set up before recoating. These defects are a reminder of my impatience, and are adding a considerable amount of time to prepping the mold. Don't make the same mistakes I did
I was a little stressed about how I was going to flange the mold, but I figured it out. I'll use expanding foam and make a line on some wax paper. Once is dries, I'll cut it into small sections 1"-1.5", then trim it into rectangular blocks. Those will be my forms. I'll prep the outside of the mold with a quick blast on the angle grinder and pre cut strips of glass cloth corresponding to the blocks. I'll then saturate the cloth and wrap it around the foam blocks and stick it to to outside edge of the mold. Then I have a perimeter flange :woohoo:
FRANKEN Z!
Last edit: 09 Jul 2010 07:53 by porchev914.
- porchev914
09 Jul 2010 12:51
So, the expanding foam block idea sounded really good in my head, but when I went to do it, it seemed like alot more work than was necessary. I thought "why not just apply the foam to the mold, then trim off the excess, then lay fiberglass over that?" So thats what I did
Now I just need to wait a bit for it to set up, then start trimming and smoothing
FRANKEN Z!
- loudhvx
09 Jul 2010 13:13
Looking good, but that last photo somehow makes me hungry for a deep dish pizza with a stuffed crust.
Yeah, I'm from Chicago. :laugh:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- porchev914
09 Jul 2010 13:33
Mmmmmmm, deep dish stuffed crust. I've never had it, but it sounds intoxicating. ..... throw in a pitcher a brew and it's the perfect meal! :laugh:
FRANKEN Z!
- PLUMMEN
09 Jul 2010 14:32
testarossa wrote:
www.dragboatcity.com/boats-sale/Dante%20Cole%20Molds%20.html now youve got me thinking! :woohoo:Adam, count me in as a follower. I have just been out of internet range for a few days. More on that later. I'll post a travelogue in chit chat. Excellent thread, and as I predicted, we are all learning. Makes me wonder what all these guys who build CF boat hulls and vacuum bag 'em must go through. Keep up the good work.
- testarossa
09 Jul 2010 15:32
I have been wanting to build a boat for a while now. That will have to wait. Plum, that hull would definitely add some excitement to your life.
Adam, I was thinking that particular picture looked like an attempt at cake baking gone horribly wrong. :laugh:
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
09 Jul 2010 15:37
- testarossa
09 Jul 2010 15:52
I know where I would take one of those to run it:
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
09 Jul 2010 15:58
we can all make the pilgramage to omr's backyard in november to see the nationals in chandler az
