vinyl hose, brake fluid?
- loudhvx
Re: vinyl hose, brake fluid?
03 Mar 2010 22:37
When I worked at a bicycle shop back in the 80's, Aquanet was the first choice in grip adhesive.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- polkat
03 Mar 2010 22:44
I miss-understood your original post.
Here is some text from a website dealing with a Mitsubishi car brake resevior mod
"No parts store will sell brake hose by the foot, not that we could find anywa."
Which sort of answers that question. But it goes on to say.....
"....so go to a hardware store and get some air hose. The air hose you want is red-orange on the outside and black on the inside. Many kinds of rubber won't withstand brake fluid, which is why it's important to not use any old hose, but this stuff is up to the challenge."
I don't actually know if that is true, or if you can get the stuff in metric sizes (I would guess yes). You can buy it by the foot. Just some food for thought.
- Old Man Rock
04 Mar 2010 03:37 - 04 Mar 2010 03:38
9am... Not sure up there in the North but out here (AZ), our local auto part stores such as Checker sell oil/gas/brake line by the foot and it's only $1-2...
For that short of a run, hell they'd probably give it to you for free if you where buying something else you needed, such as oil, plugs, cleaning/paint supplies etc...
What about this, since you're upgrading to a different brake system, anyway to cut a piece of the old kz brake lines, preferable mid section area?
Just a thought big guy....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 04 Mar 2010 03:38 by Old Man Rock.
- 9am53
- homebrew, and some bbq
04 Mar 2010 04:16 - 04 Mar 2010 04:17
I tried that and cut my brake lines that I replaced to see the size of the hole and it's about 1 or 2 millimeters in diameter, so way too small. One thing I am thinking is going to the boneyeard and stealing that bit of hose that connects the rear fluid reservoir to the mc on some old bike...
OMR
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
Last edit: 04 Mar 2010 04:17 by 9am53.
- mark1122
- Keep twisting it
04 Mar 2010 05:04
I had a similar problem last summer. i had the stock hose, but it was toooo short to mount the reservoir behind the side cover.after a few wasted trips to the auto store , i ended up with a piece of steel fuel line. i cut the ruber brake hose in 2, and spliced the steel fuel line into the middle .
i like the idea of the air line, hopefully it has the right I.D. u could wrap it with electrical tape if u dont like the color.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 9am53
04 Mar 2010 05:07
I think the clear hose would look great, and I could spare a couple incehs of my new fuel line, but I don't want to die either.
'84 GPz900r
'71 CB350
'71 CB350
- 9am53
04 Mar 2010 06:05
What it looks like I am going to do is find some braided SS PTFE tube from eBay for this hose, that way it will match my new brake lines and look much better than a black hose from kawi
'84 GPz900r
'71 CB350
'71 CB350
- mark1122
- Keep twisting it
04 Mar 2010 07:31
1 other option may be to use dot 5 silicone brake fluid. it does not harm paint so should be easier on hoses. i have always used dot 5. it is not hydroscopic, so it lasts longer.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 9am53
04 Mar 2010 07:38
I think I will stick with good ole DOT3...my only issue with getting the larger diameter brake hose will be shipping to canada unfortunately...
'84 GPz900r
'71 CB350
'71 CB350
- trianglelaguna
04 Mar 2010 08:03
dog teams runnin late this season?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- 9am53
04 Mar 2010 08:48
maps.google.ca/maps?hl=en&tab=wl
I just counted 13 states that are further north than where I am at...no dog teams here!
Shipping to canada is always 3 or 4 times what you guys pay, so often times shipping is more than the cost of the item.
'84 GPz900r
'71 CB350
'71 CB350
- loudhvx
04 Mar 2010 10:35
By the way, stick with dot 3 or 4. It is designed to absorb water. That way the water is dissipated through the system. You don't want the water to collect in the low points and boil.
1981 KZ550 D1 gpz.
Other links.
Other links.
