KZ 650 tank leaking behind badge - options?
  • puckaveli
  • puckaveli's Avatar Topic Author
23 Mar 2006 08:18
#33673
1979 KZ650 - The paint behind one of the badges was bubbling pretty bad so I took the badge off and started picking at the paint and sure enough it was rust, so I start flaking off some of the rust and gas started leaking out from behind the mounting "plate" for the badge so I took the tank off and drained it. I'm painting and debadging the tank anyways so can I remove the badge plate and just fill it after the hole is repaired and sealed or is that plate welded in there?
I'm also looking at just buying another tank. I still have to dig into the current tank and remove the rust to see if any other leaks exist and deep the rust is. But if it gets worse another tank might be a better option. This site has several tanks for KZ650's but no year so my next questions is what 650 years and models are interchangable? And they have a few listed as CSR that look different from mine.
www.cycleramasales.com/site/1538094/page/642659
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: KZ 650 tank leaking behind badge - options?
23 Mar 2006 11:06
#33738
What model '79 do you have? I just saw your pics, you have a B model.
B and C models from '76 to '80 are the same tank.
D (SR) models from '78 to '81 are the same.
F series from '80 to '83 may be the same as the B and C models as well.
Check out this site for the different 650 models: 650s
Post edited by: rstnick, at: 2006/03/23 14:13
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • RonKZ650
  • RonKZ650's Avatar
23 Mar 2006 16:17
#33819
1978-1979 KZ650B and C is a direct replacement for your tank, but 1979 had different badges. 1980 really wasn't a model offerered in the USA at least. 1977 tank will also work, but your fuel petcock will not fit unless the outlet hole is enlarged on the tank. 1976 really wasn't a model of KZ650 although some were possibly titled as 1976 because they were built in 1976. For all intensive purposes, the KZ650B and C was a 1977-1979 model run.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
23 Mar 2006 16:26
#33824
What I've used on tanks that you can't seal using Kreem or Por15 is an marine epoxy resin to line the tank.
West systems marine resin epoxy. 105 resin and
205 hardener
This mix creates a hard shell inside the tank that's impervious to gasoline. Use a 5:1 mix.
  • reborn650
  • reborn650's Avatar
23 Mar 2006 20:44
#33891
Hey puckaveli. If you are interested I have a really nice spare Kz 650 tank with petcock, gas cap and key I will part with if you are interested. Check your messages I sent you a u2u.
Cheers-Colin Firth
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
23 Mar 2006 22:36
#33914
if not , can i buy the cap & key?
  • puckaveli
24 Mar 2006 08:45
#33977
Thanks for the help I went to a local salvage yard and they had a good selection of KZ tanks, so I got a nice 650b tank for $100. www.cycletherapy.com is the place in case you need something.
  • wiredgeorge
  • wiredgeorge's Avatar
24 Mar 2006 13:12
#34021
You can't fix rust. If the entire area is rust, you need new metal and will have to cut and weld or at least cut and braze. If the area is small and you can grind off the welded-on badge bracket, you can use JB Weld. That will fix the gas leak permanantly. Since the rust occured from the welded-on bracket, hopefully the tank rusted from out to in rather than vice-versa.
  • BLOODYJACK2
  • BLOODYJACK2's Avatar
26 Jun 2017 12:42
#765429
I fixed a badge leak in the 80's by brazing in new metal it can be silver soldered too. I don't know if this is still valid because cars now have catolitic converters and i m no sure if this makes a difference. I rode the bike to my buddy's shop we emptied the tank of gas and stuck the fuel filler hole over the exhaust of his car and left it on tick-over for 20 minutes. The carbon monoxide killed the gas fumes and we able to braze on the tank. Let it cool down put it back on the bike and rode home.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
26 Jun 2017 12:58
#765430
Thanks for the post. I hope you are not planning on a big conversation here. Nobody has posted to this thread in more than 11 years. Many of the participants have moved on.
  • Nessism
  • Nessism's Avatar
27 Jun 2017 11:37
#765511
TexasKZ wrote: Thanks for the post. I hope you are not planning on a big conversation here. Nobody has posted to this thread in more than 11 years. Many of the participants have moved on.
Good news is he used the SEARCH function to find info!
  • martin_csr
  • martin_csr's Avatar
28 Jun 2017 05:17 - 28 Jun 2017 07:32
#765563
This is a topic I reference occasionally when someone has a fuel tank in poor condition & wants to line it. particularly the reply by Jeff.Saunders.
tag = west systems marine epoxy.
Last edit: 28 Jun 2017 07:32 by martin_csr.
The following user(s) said Thank You: JR
