throwing in towel on \"rusted rail\" - so, best way to prep for painting?
  • primemover
  • primemover's Avatar Topic Author
07 Jan 2006 16:06
#16565
Hi Guys....
I've been trying my best (various techs) to get the rust off of that rack I picked up....
i think she is too far gone...
so, if i wanted simply to paint it some kind of accent color, what is the best way to start the process?
should i simply clean it up the best i can and then SAND THE HECK out of it??
I do have a wire brush attachment for my drill....
perhaps then move onto sand paper (coarse -> fine)???
thanks....
- prime
ps. i've tried various ways to up load a pic (no luck... tried resizing, as a JPG...?)
  • mykznme
  • mykznme's Avatar
Re: throwing in towel on "rusted rail" - so, best way to prep for painting?
07 Jan 2006 16:45
#16572
sand the hell out of it to get all the rust off then get an adhesion promoter.
www.levineautoparts.com/buladprom.html they sell this at wall mart.
clean it spray it with the promoter allow full cure and scuff the promoter with 150 grit.
then your ready for primer coat.
if you spray paint on chrome it will peel or chip
even if you sand it.
and yes the pic must be jpg. also the filename can only contain alphanumeric characters with no spaces.
Post edited by: mykznme, at: 2006/01/07 19:48
R.I.P. Odd Ivar
  • primemover
Re: throwing in towel on \"rusted rail\" - so, best way to prep for painting?
07 Jan 2006 17:49
#16584
thanks.....
looks like i'll be busy next weekend!
also, thanks for the tip re: pics....
this one might just work (resized, jpg, no spaces in file name!)...
[img size=461]C:\Documents and Settings\Bill\My Documents\files bill\bikes\kz400\rustedrack.JPG[img size=461]http://kzrider.com/media/kunena/attachments/legacy/images/rustedrack.JPG[/img]
[/img]
no i'm just throwing the kitchen sink at this pic thing!
  • primemover
07 Jan 2006 17:51
#16586
test of pic method
  • wireman
  • wireman's Avatar
07 Jan 2006 17:57
#16588
thats more like it!id say thats definately past the polishing stage,id try sand blasting youre not going to hurt it any and it will rough it up good enough to get some rustoleum primer to stick to it!goodluck,happy wrenching!
  • OKC_Kent
  • OKC_Kent's Avatar
07 Jan 2006 19:40
#16611
Looks like a prime candidate for that electrolysis method of rust removal. Do you have a car battery charger?
www3.telus.net/public/aschoepp/electrolyticrust.html
Post edited by: OKC_Kent, at: 2006/01/07 22:54
Cashion, OK
78 KZ650 B2 85,000+ miles
  • mykznme
  • mykznme's Avatar
07 Jan 2006 21:20
#16628
here is another pre primer product.
this would actually be better for your application than the adhesion promoter.
www.ospho.com/
this stuff seals as it eats the rust.
sandblasting is great if you have access to it.
the ospho will run you anywhere from $4.00 to $12.00
depending on how much you buy and can be easily found at hardware stores and paint stores like sherwin williams. if thats the only peice your working on then a pint should cover it.
Post edited by: mykznme, at: 2006/01/08 00:25
R.I.P. Odd Ivar
  • primemover
08 Jan 2006 07:46
#16686
wow!
that seems like an interesting option....
will look into it
thanks
  • primemover
08 Jan 2006 07:47
#16687
thanks for all your help....
- prime
  • DanOz7Five0
  • DanOz7Five0's Avatar
08 Jan 2006 08:30
#16694
I doubt they are the same size but there is a junkyard near my work that has a rack like yours with no rust but on a 550LTD. I can grab it if your interested. I took a pretty good look at it and it is very clean.
  • donthekawguy
  • donthekawguy's Avatar
08 Jan 2006 14:40
#16752
Blast it and have it powdercoated.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • primemover
08 Jan 2006 17:52
#16790
thanks for the offer, but no need....
i'll clean this one up....
it will give me the chance to try a few different rust removing options (got to learn anyway, the bike needs some real TLC.... no time like the present!)
- prime
