aluminum polishing/ write up/ pics
- DanOz7Five0
Re: aluminum polishing/ write up/ pics
08 Jan 2006 08:54
Ok I have the electric one that spins at 10,000 and 20,000 rpm. I have used my variable speed electric drill at very low speed with better luck.
One day while working I had to do some demonstrations with the Dremel, so I brought a cam cover in and marked down for "store use" some wire brushes and abrasive pads and did some work on my parts, but I couldnt continue marking things down as fast as I was going through them.
We have a Dremel rep that comes into Home Depot that said that when polishing you want the speed as low as possible, just enough to keep the bit turning.
- steell
08 Jan 2006 10:58BUFF RUNNING SPEEDS
For best results your wheel should maintain a surface speed of between 3600 & 7500 Surface Feet Per Minute. (SFPM). The higher your speed, the better and quicker your results.
Formula for calculating surface speed of wheel in SFPM.
SFPM = 1/4 x diameter of Wheel x RPM (revs of spindle per min.)
According to:
www.caswellplating.com/buffs/buffman.htm#speed
