Powder coating frame
  • zmaniscalco
  • zmaniscalco's Avatar Topic Author
18 Mar 2007 15:39
#121335
I am powder coating my 78 kz1000, I need to know what to watch out for, I am not able to get the bolts out that hold the foot pegs, is that a problem? If I leave them on what do I do to cover them? I would like to bring everything I can to the shop at the same time I am doing the frame, what to bring, battery box, brake bar, ????
I will also be putting Kosman's motor mount kit, will drilling out the hole be a problem???
Any other advice on the subject would be nice...
Thanks
Frank
78 kZ1000
79 KZ1000 Ltd turbo
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Powder coating frame
18 Mar 2007 15:47
#121337
The footpeg mounting bolts have lock nuts on the backside of the frame. I think they're 13 or 14mm nuts. Take those off and it'll make taking the peg bolts out a lot easier.
Take whatever you want powdercoated to the shop. What you take is up to you.
Drilling the holes shouldn't be a problem and you're most likely going to have to run a tap through any threaded hole on the frame, and whatever else you're powdercoating, anyways.
Later, Duog
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • zmaniscalco
18 Mar 2007 16:50
#121354
Thanks,
but I pulled the nut off and put a pipe wrench on them they will not come out I hit them with a hammer also thinking they might just push in and not thread in.
Will my new steering bearing go in ok after podwer coating?
And one more thing, can I powder coat a nuts?? Or is it better to paint(thinking of gloss black)
78 kZ1000
79 KZ1000 Ltd turbo
  • StreetfighterKz
18 Mar 2007 17:18
#121363
My '78 and '76 have thread in bolts for the foot pegs. The steering head bearings shouldn'be be a problem after you clean the powder coat from the steering head...unless the shop you're using has a big enough plug for it and then you'll be fine.
I'm not sure about powdercoating nuts. I would pain them black since it'd be a lot easier to touch up later.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • zmaniscalco
18 Mar 2007 19:09
#121389
me got bigger pipe wrench....
I am ready to go...well get started anyway.
78 kZ1000
79 KZ1000 Ltd turbo
  • zmaniscalco
18 Mar 2007 19:11
#121390
wish me luck
I should get it dropped off this week
78 kZ1000
79 KZ1000 Ltd turbo
  • wireman
  • wireman's Avatar
18 Mar 2007 22:04
#121452
make sure they mask off anything you dont want powder coating onwith high temp tape;)
  • zmaniscalco
19 Mar 2007 08:18
#121546
thanks that sound like a good idea, can I do it before i bring to him, and should I fill the threads of my frame with trash bolts and nuts?
78 kZ1000
79 KZ1000 Ltd turbo
  • wireman
  • wireman's Avatar
19 Mar 2007 10:08
#121570
they should have some sort of plugs for the threads,just make sure to point them out to the powdercoater;)
  • KzJim
  • KzJim's Avatar
19 Mar 2007 12:42
#121606
Dont put bolts in, the powder will build up around the bolt and when you back it out it will leave a ridge, crack and give water a place to go. I dont like plugs either never used them. they do the same thing, the build up will live a little ridge that will smash when you tighten a bolt down, better to leave open and run a tap thru it after.
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • elseed
  • elseed's Avatar
19 Mar 2007 14:16
#121628
Consider some masking or other treatment (like specify light coat?) for the steering head VIN. Can be a headache at the DMV, smog testing place, etc. if that gets coated over such that it's unreadable. I asked mine to be masked and it wasn't -- still readable, but pretty shallow now.
Ideally, would be better to drill and fit Kosman kit before you coat it. I have one and it took a little fitting work. Among other things, less risk of messing up your fine new powdercoat at those drilling spots. Build, Tear Down, then Finish [everything I know about bike builds I learned from the Discovery Channel :whistle: ] But don't sweat it, it's probably OK either way.
Oh yeah, one other thing: When you pick it up, shake the sandblasting media out of the frame BEFORE you put it in the back of your car.
'75 Z1B with mods
  • elseed
  • elseed's Avatar
19 Mar 2007 14:22
#121630
One other other thing: I think you oughta remove the peg bolt hardware if you can. I can't exactly remember but pretty sure they're threaded into the frame fitting in addition to the backing nut? Like suspenders and straps arrangement. I think you have to twist 'em out after the backing nut is off.
Got a picture of one around here somewhere:
Post edited by: elseed, at: 2007/03/19 17:24
'75 Z1B with mods
