best paint remover
  • fergyfer
  • fergyfer's Avatar
Re: best paint remover
29 Dec 2005 07:44
#15010
If you read the rusty tank writeup in the articles, this method works unbelievably well. My tank inside was brown and scaley, and after using this procedure, my tank is silver inside, and a month later, still is. The second step, using phosphoric acid (naval jelley) to treat it seems to keep it from rapidly starting to surface rust.
Before this procedure, my gas tank turned the gas red/orange...
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
30 Dec 2005 10:53
#15243
Best paint stripper-elbow grease with maybe a wire wheel or sander to help.
  • racer54
  • racer54's Avatar
21 Jan 2006 19:41
#19170
If brake fluid is used, is there a chance of the metal being contaminated with a chemical so that the paint doesn't stick as well? I know if you use wax containing silicone and some other chemicals and then try to sand and paint later, the soaked in silicone in the paint from the wax will keep the paint from sticking. I know this from experience.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
22 Jan 2006 01:00
#19193
"aircraft remover" got a kick first time i saw it.
what is this electrolyte method? details?
OK, found it myself...
www3.telus.net/public/aschoepp/electrolyticrust.html
-Duck
Post edited by: Duck, at: 2006/01/22 04:24
  • Duck
  • Duck's Avatar
22 Jan 2006 01:04
#19194
Was supposed to be funny. Brake fluid seems to be the best because it does such a good job when one doesn't want the paint removed. I know from experience ;-)
There are solvents for removing silicones but you're right, once in the metal it's a real PITA...
-Duck
