KZ650 tail onto a KZ1000a
  • indykaw77
  • indykaw77's Avatar Topic Author
12 Oct 2005 15:43
#1132
Well....started this little mod today. First pic is as I got it, along with fit issues.
Width problem was that the seat rubbed part of the tail as it closed. "Fixed" that with a dremel cut off wheel on the tail, and hadda bend the seat pan EVER SO Slightly to allow clearance. Pic 2
Did initial mock-up for fit and to see where undertail mounts would have to be. Those ended up being an inch and change outboard of the stock KZ under mounts. Cut some trusty ol' 1/8" aluminum flat stock, measured and drilled 2 holes and viola`...new mounts! They are angled slightly UPWARDS to keep the top of the 650 tailpiece "level" to the eye. Got some wiggle-room there, so will need 2 helper eyeballs when final fit comes along.
Tricky part will be front mounts under seat. The 650 tail isnt "flat" enuff to just drill holes and use stock mounts, so will most likely 'glass in a "boss" on the underside of the tail and sand to fit where it will mount, THEN drill the holes and mount.
Always liked the up-sweep of the 650 tail, and it hasnt been TOO bad to get on a 1000......YET! Will clean up my cut edges when I know everything else fits. Salt and pepper to taste!
Kawasaki Motorcycles...because cars lean th wrong way!
  • indykaw77
Re: KZ650 tail onto a KZ1000a
12 Oct 2005 15:50
#1136
Rats....pics wont post....:(
  • ronboskz650sr
  • ronboskz650sr's Avatar
12 Oct 2005 16:05
#1141
Pat, just saw your other post, I was out...let me know if that doesn't work.
  • indykaw77
Re: KZ650 tail onto a KZ1000a..pics this time maybe????
12 Oct 2005 16:49
#1151
Lemme see if I got this straight now.....
Maybe they'll be here after I click "submit".....
  • ronboskz650sr
12 Oct 2005 17:03
#1152
That's going to look great! Sometimes I think about painting a primer bike. :laugh: Just looks so good...then I get over it.
  • GargantuChet
  • GargantuChet's Avatar
12 Oct 2005 18:48
#1175
I wonder whether it would be possible to wetsand primer to the point that it could be clearcoated... Of course, you'd have to use a VERY flat clear.
I might have to convince my bodyman friend to try that next time I'm in the garage during painting.
  • GargantuChet
12 Oct 2005 18:49
#1176
Grrr to duplicate posts. I wish I could delete posts again. :angry:
Post edited by: gargantuchet, at: 2005/10/12 21:51
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
12 Oct 2005 18:51
#1177
The 650 tail has always been my fave. Looks good so far on yours. Keep us updated.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • ronboskz650sr
12 Oct 2005 19:03
#1183
.[/quote]
Yes! You can clear over primer to seal it if it's going to be a driver for a while before you can paint it. If you are in the final primer coat, and it's sanded out, it should all be one color, anyway. When I am ready to paint, my primer looks like a flat grey paint, so I wouldn't hesitate to clear it for a gloss grey finish, except fot one thing. You can sand the paint between the coats for an even better finish, and do less sanding in the clear. That leaves the clear deeper for a deeper gloss, if that's the goal. It might not be on a vintage machine. Million ways to skin this cat. :woohoo: :woohoo: :woohoo:
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
12 Oct 2005 19:15
#1187
Sorry to highjack the post.
Ron, what type of sanding are you doing between coats? Wet and what grit?
As well, what prep? or how much prep should I do to my Rickman fairing? It's painted white. Just a sanding to give the primer something to hold on to? And again what grit?
Just saw your instructions in your tank post Ron. Thanks for the info. But for a newbe painter, where can I find a good step by step guide to prepping and painting?
Post edited by: rstnick, at: 2005/10/12 22:34
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • ronboskz650sr
12 Oct 2005 19:35
#1196
Rob, check your PM. U2u..whatever.
  • R Dresden
  • R Dresden's Avatar
12 Oct 2005 19:55
#1205
That tail piece does look pretty nifty there my man. Makes it look more aerodynamic/rocket look. I like it!
Peace,
Rodger B)
