rear tire size recommendations-KZ1000 ST (1979)
  • Bob_79KZ
  • Bob_79KZ's Avatar Topic Author
Re: rear tire size recommendations
26 Sep 2006 18:44
#79881
WG...yeah, you're right. I might as well have asked which is better, Ford or Chevy.
But, after reading all the replys and doing a little research on-line I guess I'd better put a Dunlop on the rear so it matches the front.
When they wear out maybe I'll try something different.
As for the master cylinder thing, my resovoir is mounded right on the brake cylinder. Other than that it looks like they mount the same. Just find a spot for the resovoir I guess.
Happy trails...
Bob
  • wiredgeorge
  • wiredgeorge's Avatar
27 Sep 2006 12:00
#80056
Bob, In 79 they seem to have used a one piece master cylinder w/resevoir. In 80, they used a separate resevoir connected to the master cylinder with a hose and bolted the master cylinder to the battery box via a bracket. Dang... the differences between the 79 and 80 have bit me a couple times! I will just put on a one piece master cylinder as I have several.
  • Bob_79KZ
27 Sep 2006 19:28
#80161
WG: There you go...simple solutions for simple problems.
I have the Clymer book for this bike and it shows the master cylinder with the resovoir attached to the top end.
And since the bike has been owned by the same family since it was brand new I'd have to guess that that is the way it was installed in March of 1979.
By the way...they got tired of it sitting around in the back yard and GAVE it to me. Gave, as in free...
It took me a week to get it running and I drove it home. They didn't think it would ever run again when they parked it in 2002.
Happy trails...
Bob
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
29 Sep 2006 07:22
#80445
I'd stay stock size on the shafty IMHO.
I just put a pair of 404's on my 550 and they are great but for the 1000ST I plan on 501's as the 404's seem to be matched to the performance of the 550 but when I have the 1000 in a corner a bit too hot I want it to stick better due to the mass of the bike.
I have a spare front rim and tire I might be getting rid of some time this late winter after I hopefully get to tear-down the 1000.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • Bob_79KZ
29 Sep 2006 12:26
#80497
KZ_Rage: Well, thats what the problem is. What IS the correct rear tire size? The sticker on the bike calls for 4.50x17 tires but they don't make tires in inches anymore. So I'm having trouble converting inches to metric.
Most of the guys on here recommend 130/90x17. Is that EXACTLY the same as a 4.50x17? Is it taller? Wider? Smaller? Shorter? I'm so confused...
Bob
  • KawasakiBob
  • KawasakiBob's Avatar
29 Sep 2006 12:48
#80500
OKIE DOKIE, I'll try to help a tad.
Sizewise 140/70-17 140= width, 70=profile, 17= rim size
As for alphanumeric to american to metric size conversions theyre available from almost every tire manufacturer online.
As for changing tire sizes, it can be done, but keep in mind (mostly for newer bikes) that it will change the handling of the machine.
The Oem's don't just pick tire sizes out of the air, but instead the ergonomics of the machine is designed around the tire sizes along with the other factors.
Also keep in mind if it'll fit, not just checking the rear of the swingarm but the front part as well.
  • Bob_79KZ
29 Sep 2006 19:51
#80574
KawasakiBob: I'm try to stay as close to stock size as possible.
It calls for a 4.50x17 rear tire.
Most everyone recommends a 140/90x17.
4.50 inches = 114 milimeters.
a 130/90 = 130mm.
Thats what makes it so confusing you see?
Bob:S
Post edited by: Bob_79KZ, at: 2006/09/29 22:54
Post edited by: Bob_79KZ, at: 2006/09/29 22:56
  • KawasakiBob
30 Sep 2006 09:59
#80657
According to Dunlops chart..
120/90 = 4.50/4.75 on a rear street tire
  • RonKZ650
  • RonKZ650's Avatar
01 Oct 2006 17:13
#80992
I just had my 1980 KZ1000E out today for the first time in 50 months. Started right up, thank you, contrary to the "wont run after sitting" I've read here. Back to the subject, my tire is still original 1980 Dunlop, but by looking at it, I'd think a modern tire that would match closest would be along the lines of a 140/90-17 if there is such a size. Pretty beefy tire on the ST.
  • Bob_79KZ
01 Oct 2006 20:42
#81049
RonKZ650: Yep, I agree. From all I've read and seen the 140/90-17 might be a bit beefy.
I'm thinking a 130/90-17 might just fit in there real nice. I have not seen a '130' but I have seen the '140' at a cycle shop and it looked kind of wide.
I'm not going to buy one for a few more months so I will continue to research it till my head is filled with so much nonsense that I will end up with the wrong tire for sure. I tend to over think a problem.
Thanks for the input.
Stay safe,
Bob
