new drive chain, more questions!
  • tcbradbury98
  • tcbradbury98's Avatar Topic Author
Re: new drive chain
19 Sep 2006 12:56
#77885
I ordered one from denniskirk, was only a $1.99, already had them sending me a front sprocket.
  • tcbradbury98
Re: new drive chain
22 Sep 2006 18:52
#78848
My bike takes a 530x100 chain. So I can remove one link from the 530x102 chain I bought, right? When you count the amount of links does that include the master link? If so I have 100 now with the master link. I cannot get it connected. I have the wheel as far forward as it will go and still short. Can I have a link added to it? Or am I stuck buying another chain? Thanks
  • tcbradbury98
Re: new drive chain
24 Sep 2006 16:23
#79244
anyone?
  • neilage66
  • neilage66's Avatar
Re: new drive chain
24 Sep 2006 17:12
#79262
If you bought the "too short" chain new, could you exchange it for one that's a link or two longer?
If you have the rear wheel full forward, can you measure to see how many more links you need than what you got now?
Dennis Kirk or no...a new chain should generally always come with a new master link.
I think you count the rivets (not including the open link ends where the master goes) from one end to the other to get the actual number of chain links. Someone here can tell you fo sho.
Good luck!
Here's a good link for you too:
Chains and Such
  • tcbradbury98
Re: new drive chain
24 Sep 2006 19:08
#79297
The chain was new, but I bought it from a private seller, it is one, (maybe) two links short, I bought a chain repair kit, if it works great, if not I will take it to the local kaw dealer and have them fix it, thanks for the info!
  • wireman
  • wireman's Avatar
Re: new drive chain
24 Sep 2006 20:57
#79353
i usually try and put my wheel back as far in adjusters as possible and still alow a litle adjustment,that extra 1"works like a poormans extended swingarm and most people dont catch it.;)
  • darkwolf29a
  • darkwolf29a's Avatar
Re: new drive chain
25 Sep 2006 04:55
#79385
RonKZ650 wrote:
In theory the front sprocket is easy to change. You need to remove the engine cover, that means removing the shift lever, left footpeg and starter cover. Now your sprocket is clearly visible, flatten the lockwasher, put on a big socket and remove the nut. This is when the "in theory easy to remove" comes in, the nut can be anywhere from finger tight to 300 ft/lb tight. Once you get the sprocket off a 1 tooth change should not require a different length of chain. I should change my "all chains come with a masterlink" to every chain I've ever seen has come with a masterlink. In my mind if it doesn't come with a masterlink it must be one of those great deals,(otherwise known as a Chinese POS). How in the World do they expect you to use a chain without a masterlink? I suspect different brands of chain have slightly different diameter pins ect, "brand A" masterlink is not a good idea to use with a "brand B" chain.
Working on taking my front sprocket off now. :( I think it's got the 300ft/lb tight. :( Any thoughts on how to remove it, without a impact wrench? I'm trying to get the money together for one, but it will be a few months before I can.
  • wireman
  • wireman's Avatar
Re: new drive chain
25 Sep 2006 05:11
#79387
leave chain on,have someone hold brake and jump on breaker bar!:P
  • JMKZHI
  • JMKZHI's Avatar
Re: .
25 Sep 2006 05:14 - 03 Dec 2008 16:59
#79388
del
Last edit: 03 Dec 2008 16:59 by JMKZHI.
  • darkwolf29a
Re: new drive chain
25 Sep 2006 12:18
#79471
I went one better than that. :P LOL
I went to ebay, and got an IR impact wrench and compressor for $120 total. :) I'm most pleased, and that is much cheaper than I was thinking by looking at various online stores, and checking various home centers. :) :silly:
