single club swing arm???
- wireman
Re: single club swing arm???
02 Sep 2006 19:43
id say a stock kz1000 or 750 disc brake hub since thats probably what it was set up for,then make spacers to fit.
- Leonard Smalls
02 Sep 2006 20:04
The angle at which the chain will have to travel from the front to rear sprocket would likely cause a problems though right?
Because the 650 has a smaller engine case and frame limiting the offset of the front sprocket.
What is the best way to remedy this?
Thanks for the prompt replies wireman!!!
Post edited by: Leonard Smalls, at: 2006/09/03 02:06
- Leonard Smalls
02 Sep 2006 23:05Post edited by: Leonard Smalls, at: 2006/09/03 02:20
- wireman
- wireman
- Leonard Smalls
03 Sep 2006 00:21
I found an 82 GS1100 swing arm for cheaper, I think i will go that route. Here is the link to the one on Ebay:
cgi.ebay.com/ebaymotors/KAWASAKI-DRAGBIK...DVW#ebayphotohosting
- wireman
03 Sep 2006 06:48
yeah i was gonna ask you if that was a steel or aluminum arm.i personally prefer the aluminum arms the steel ones seem to have a lot more flex in them so they put the club on the chain side.if you see an aluminum one braced like that you knbow its serious stuff going on!:evil:
