Question on brake bleeding
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: Question on brake bleeding
24 Aug 2006 10:48
#72153
Both my mine do on the 650s. I assume the fountain is seen from the hole farthest from the lever?
What kind of lines are on your bike? My SR with OEM lines now feel much less solid than the 650B with new stainless braided lines. Did you hone the MC?
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • Sorf
  • Sorf's Avatar
25 Aug 2006 01:59
#72342
- Nate >>
Could have been that hole, haven't tried again lately. I'm using OEM lines, though new, (keeping bike original) The bore "looked" good, so no I didn't hone. Would there be any weeping or such if the bore was buggered? 'cos there's none of that. I guy did tell me once that the bore can wear and that a small packer (2-3mm, AKA a screw) driven into the end of the lever where it contacts the piston head, will move the piston down just far enough to resolve most wear issues. Ever heard of that one?
  • cudaosix
  • cudaosix's Avatar Topic Author
25 Aug 2006 07:43
#72394
Changed and bled the brake fluid last night. I did it per Nates instructions and it worked out fine. The reservior needed to be cleaned up a little. It had dirt or something black collected in the cornes and some on the bottom. I sucked it our easily with that turkey baster and left it clean. The front brakes are an improvement, they worked well and the lever felt fine before anyway. The rear was always a little spongy, apparently whoever bled the rear before left some air in the line. Now it works and feels much better, big improvement. I'll be doing this once a year or so from now on. Thanks for the help everyone.
  • N0NB
  • N0NB's Avatar
25 Aug 2006 15:41
#72470
Very well, Sorf. I used the lines from www.helusa.com with a black cover and from a few feet away, it's hard to tell that they aren't OEM. I think that hole acts as a relief valve so some amount of lever travel exists. Once the plunger (for lack of a better term) gets past it, the system builds pressure as the lever is squeezed.
Cuda, glad it worked out. I think that is the "secret" most people are looking for. It's been mentioned a few times around here in the past. Just be ready to spread the word the next time someone asks. :)
- Nate >>
Nate
  • beaterbike
  • beaterbike's Avatar
07 Sep 2006 06:17
#75059
How timely.
After figuring out why my bakes sucked..one of the discs was covered in Brake Fluid.
I had the calipers rebuilt (shop didn't have a kit, but plenty of seals - so for $50 calipers...done)
So last night I was bleeding the brakes using the vacum deally...or maybe put the sucky vacum deally. After a while I supplied the suction... Long story short. Still have no pressure..:unsure: so.. time to back up and try the pump open close release method.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
07 Sep 2006 07:19 - 03 Dec 2008 17:18
#75066
del
Last edit: 03 Dec 2008 17:18 by JMKZHI.
  • GPZ1100
  • GPZ1100's Avatar
07 Sep 2006 07:31
#75072
I rebuild my calipers and replaced hoses with braided stainless steel ones.
To bleed, I use speed bleeders qnd a tube hooked up to a little bottle. Easy as pie. I went through 2 bottles of Bel-Ray DOT 4 just to make sure I had it all. Worst part was constantly topping off the resevoir.
  • beaterbike
08 Sep 2006 16:40
#75337
Went back and did it by the book. Also "blead" master cylinder. Better but nor perfesct... still working on it.
