"Rearsets" on a (TIGHT!) budget....need ideas/help (UPDATE w/ pics)
- indykaw77
06 Nov 2005 19:04
OK, OK I admit it....I'm cheap! I got clearance to swap my peg mounts side-to-side and turn them around.
Now....anybody done this and swapped for the newer cool looking alloy pegs? What fits? How about shorter shift lever and brake pedal? Looked at buykawasaki.com parts diagram....no spline sizes tho...
I guess I could get new ones machined, but like I said, I'm cheap. Ideas anyone? Thanks!
Update....pics and story on 2nd page of this thread.
Many thanks to all who offered advise and ideas!!!!
Post edited by: indykaw77, at: 2006/03/15 05:47
Post edited by: indykaw77, at: 2006/03/15 10:13
Kawasaki Motorcycles...because cars lean th wrong way!
- RollingStock
Re: \"Rearsets\" on a (TIGHT!) budget....need ideas/help
06 Nov 2005 19:34
86 zx600... easyly moded to fit
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- indykaw77
06 Nov 2005 19:59
COOL!!!! Is that the pegs, shift lever, brake pedal, or "D"....all the above????
thanks man....
thanks man....
- guitargeek
06 Nov 2005 20:22
www.kzrider.com/forum/viewthread.php?tid=21570
There's what I did on my bike, it was pretty painless.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- dutchz
06 Nov 2005 20:32
Did something similar, flipped mounts upside down (so peg position will be up and back). Fabbed up shift linkage with 86 Katana shiftlever, longer mounting bolt and some spacers and unidentified shiftrod and clamp. Spline size is pretty standard between japanese bikes EXCEPT Suzuki, as far as I can tell (searched through multiple part heaps multiple times at multiple scrapyards:blink: ).
Cut&weld job on brake lever to shorten it due to lack of size 15 feet. Got some alloy racebike pegs at the scrapyard as well.
Total cost about $50, and half of that was welders minimum charge... gotta learn how to weld!
1974 Kawasaki Z1
Stock front hub and rear axle.
- twowheeledterror
Re:
06 Nov 2005 21:16
indykaw77 wrote:
How's this for a budget? You pay for shipping and I'll give you the ones off of my 86 ninja project. They're just sitting in the garage and my KZ is getting some VFR ones.
thanks man....
- twowheeledterror
Re:
06 Nov 2005 21:18
dutchz wrote:
This is a great idea. It seriously opens a whole new world of options in modification.
- dutchz
Re:
06 Nov 2005 22:39
Must...learn...welding...
I have been following your progress with interest twowheelterror. Great project!
1974 Kawasaki Z1
- twowheeledterror
Re:
06 Nov 2005 23:12
dutchz wrote:
Just wait till you see whats up next. Extra gussets, some MIG welding shots, some machine work stuff and the rear end mounted perfectly while still retaining capability to run the stock rear setup too. (No modification to the frame at the pivot area like drilling new holes.)
Post edited by: twowheeledterror, at: 2005/11/07 02:12
- rstnick
07 Nov 2005 06:22
Hey twowheeledterror, sent you a U2U. Keep us up to date with pics as well.
I've got to learn to weld as well. What type of welder/welding would be best for most metal work?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Duck
- e vica na i sau na ga
07 Nov 2005 08:47
Someone else might want to chime in here, but I've found brazing to be fine for most metal work. It costs a little more for the material but on mild steel, a good braze is stronger than a crappy weld and, at least for me, seems a lot easier. (read that as Duck can't weld worth a damn, yet). I have been using a gas torch for heavier stuff and just use the little mapp cas torch for small stuff around the house like broken cabinet hinges, tiller gas tank, .... Looked at a buds FT500 frame bracing yesterday. He brazed using an electric arc welder. The welding supply store has flux coated rods in different filler materials.
IIRC the Rickman frames are brazed. Most bicycle frames are brazed.
-Duck
-Duck
- twowheeledterror
Re:
07 Nov 2005 10:03
rstnick wrote:
I just use a small wire feed for now. I prefer to use something gas shielded with 75/25 Ar/CO2, but sometimes get stuck using a friends flux core.
Flux core will weld just as well, but isn't so pretty so you have to grind the welds out to smooth them up a bit.
I will definitely keep everyone posted with pics and such.
